  2. Add color to existing color based on attribute?
  3. "Mud worms".Heightfields+SOP solver
  4. Permission Denied?
  5. Vellum export alembic
  6. egg explosion
  7. Vellum export alembic
  8. In fact, I have yet to find a operator definition type that has the 'New Output' option unlocked??
  9. Nature fun
  10. Pyro renders taking way too long
  11. Hi! I create these mountains on my shape with a noise by getting that noise to affect the @P.y attribute. Of course the mountains are thinner when my shape goes more steep, because the points distributed through the Z axis are more dense there. To resolve this I thought I should use a different Pos for the noise, so I created a grid and put it in the second input. But when I use getattrib(P) on that input and plug it into the noise, I don't get the expected results. (It seems to do nothing much) Is it that you can't use differents Noise pos' like this? Does the topology have to match with the geometry or something? How does this work, exactly? How would one go about distributing the noise position along the Z-Axis? So that you have just as thick mountains everywhere, no matter how steep? Hope you can help me. Thanks.
  12. Nature fun
  13. Vellum export alembic
  14. As the title says, when I create a new Material VOP asset the 'New Output' option in the Type Properties is greyed out. If I define export variables inside my surface shader code the 'Shader Call Export Variables' VOP will not bind them. Assigning values to eg. Cf directly in the VEX Surface code does nothing. How could I output eg. a vector from a Material VOP Asset?
  15. Yesterday
  16. egg explosion
  17. Nature fun
  18. Animate it by hand. there are three basic types of expression based animation between two frame values, mix and match as you like: //linear: float tx = fit($FF,1,10,2,21); //exponential: float tx = fit01(pow(fit($FF,1,10,0,1),3),2,21); //smooth: tx = fit01(lerp(1,10,$FF),2,21);
  19. Vex anoise
  20. Nature fun
  21. Nature fun
  22. Vex anoise
  23. Someone answer me on the Redshift forum. There is a "redshift_instancefileSOP1" that do exactly that: enable to view the proxy in the viewport. I was not aware of that node.
  24. Vex anoise
  25. Vellum export alembic
    Well, I succeeded one time, but since then I can't reproduce what I did, could someone please take a look at the hip file and tell me how to separate object while exporting as alembic, test_alembic.hip
  26. VOPs - output to @P.y.
    Nice! Thanks u both.
  27. Vellum cloth preset settings
