Hey guys wondering if anyone can give me some ideas to tackle this effect on a heightfield: https://twitter.com/Jose_Molfino/status/1669804412569567233 The artist Jose says that it's a heightfield expanding inside a solver and a gradient field based on height is used for advection. Does anyone know how that works? How would you advect calculated values like gradient field vectors? Thank you!
Caden joined the community
3delight shaders in houdini
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
