  2. More Particles Following a PATH!
  3. Now it works fine , thank you.
  5. //set a wrangle to run over primitives int primpts[] = primpoints(0,@primnum); removepoint(0,primpts[0]); removepoint(0,primpts[-1]);
  6. Dam! no reply on that topic : / I'm looking into PFtrack atm too... Trevor, have you used it with Houdini ?
  7. Noise on ramp transition (edge)
  8. Modeling questions (remesh, polyfill)
  9. Rendering Cola
  10. Hello everyone, I am working with volumetric capture data and would like to have points scattered on it that moves with the data but also doesn't chang every frame. The issue is that the geometry, primitive number and uv's keep changing every frame. So I can't do the same trick I can do with mocap data using the primuv attributes. Anyone have any experience with this and how I should handle it?
  11. animate normal like sea ​​urchin
    Thank you illusionist!!!!
  12. Simple RBD hanging
  13. Hi Masoud, padzero() expression wrapped around the clamp() adds those zeroes: $HIP/tex/Display_A_`padzero(4,clamp($F,1,130))`.jpg https://www.sidefx.com/docs/houdini/expressions/padzero.html
  14. How to select a bevelled edges?
    Submitted an RFE for this
  15. Rendering Cola
  16. you may want to lower resize_container/Bounds/Field/FieldCutoff
  17. Building a beast Houdini + Redshift mainly
  18. export texture
  19. snapping point to a Null
  20. Modeling questions (remesh, polyfill)
  21. Vellum jitters non-stop without loss of energy!
  22. Yesterday
  23. This .hip needs more work to do but yes, i think it is possible too. heightfield on such shape_01.hipnc
  24. Disable Simulations on Startup
  25. Select Outside Edges Only
  26. Hello, Here is short video showing how volumes can be used to shade and texture semi-translucent organic things. Volumes For Organic Assets This approach allows to achieve close-up realistic organic look for semi-transclucent assets where SSS or colored refraction is not enough. An object with UV's is converted to signed distance volume with UVW grid. Then volume is used to set density and perform uv lookup in rendering. This way density can be adjusted by depth. I.e. not so dense near the surface and very dense at the core. Or not very dense, then dense patch like island of fat, then not dense again. UVW grid is used to texture volume. Different textures can be used at different depth. This approach allows very flexible yet powerful way to place any texture at given depth. Texture X at depth Y. I.e. big veins are 5mm under the surface. This approach is best for close up organic hero renders where SSS or refraction are not looking good enough. Attaching example file volumetric_textures_example.hip
  27. Rotate orthographic (top) view?
  28. Hi, many ways to do that... here is one: make a "group by range" node, choose points as a group type, and put 0 for start, 1 for end, and check inverse range. This will select the last point. make another group, with point 0. blast those 2 groups. a shorter way would be a wrangler: put down a point wrangler node. and type this : removepoint(0,0); if(@ptnum == (@numpt-1)) removepoint(0,@ptnum); first line remove point 0 (the first point of the line). (0,0)means : (geometry entering slot number 0 of the node , point number 0) second line reads : if the actual point number is equal to the number of points minus one (the last point of the line) third line : remove that point
