Access Detail Attribute In An Expression
Are you saying this will only work when the detail attribute is a string, rather than a float or integer? I tried setting the detail attributes as strings with: s@start_frame = chs("start_frame"); s@end_frame = chs("end_frame"); If I remove the backticks then use: fit($FF,detail(0,"start_frame",0),detail(0,"end_frame",0),0,1) I don't see any errors, but unfortunately it doesn't animate the carve. Reading a detail expression like this goes against what I've learned when using this with VEX, where it expects 'details' to read a string attribute, not 'detail' Here's the updated .hip file: carve_read_detail_attribute_v2.hiplc - Today
GlennimusPrime started following Access Detail Attribute In An Expression
It's possible to add some type of noise with vops?
Hi guys, I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work! How can I fix it? Thanks for helping.
- refraction
- background
how to create this curly advected lines
djehsan89 replied to djehsan89's topic in General Houdini Questions
Thanks Hannes.
