  2. Hi George, It should be simple to play back any simulation , exporting bgeo or using Sim cacha from the Autodop network. I can not figure out what you are having Issues with by just your explanations. Her are some snap shots, Are your using the expresion $F with your bgeo sequence. It would be much easier if there where a scene like yours or a simple version to see exactly what you have. Cheers , but this should be a simple thing.
  4. Fuse SOP 2.0 No unique?
  5. Houdini 18 Wishlist
  6. Spyrogif
  7. Yesterday
  8. Hi, In H17.5 the fuse sop has been replaced by a new one that doesn't have the unique tab any more. Any ideas on how to recreate the same feature using other SOPs? basically a way to split vertices that have common points and generate new points. Regards, IA
  9. Letter Rising from Sand/grains COLLISION issues
  10. Hello! I have recently been offered my FIRST FX job! I am familiar with Maya, and some Max, but this job requires that i use Houdini, so now i am all in! VERY EXCITED!!! I have a scene where i have to make some letters rise from sand. The issue is that i cannot get things to collide correctly. Doing my research i have tried using it as a RBD object, and using a trail sop to computer its velocity, but i still dont see any collisions. I use static object, pointing to a VDB smooth as the proxy geo, and all of the collision detection/mode set to volume, but no collisions still. I set the sim up with an initial state file too. Could that be the issue? When i take away the VDB to polygons and VDB smooth, delete and just run the sim as a regular static object, everything works! But...i get some weird artifacts rendering. What is the best approach to this method in Houdini? Im sure the solution is just a setting away, but im lost here. Any suggestions? LetterSetup_001_collProbs.hip
  11. Thank you Tesan but I could not make it work... Here is a gif and my hiplc file... mixamo test 1.hiplc
  12. houdini dop inherit velocity
  13. play with this (maybe it's this that you want) Houdini 16 noise.hipnc
  14. post .hip file and someone gonna Play on Cd some noise. Just please post your file
  15. Nature fun
    Birdy DODO L-system
  16. Hi, I need to feed Cd with a noise that will stick to the surface of an imported animated character (fbx or alembic). Thanks for helping!
  17. Toms "Learning Houdini" Gallery
    @Thomas Helzle ok Thanx
  18. For the align topicsmay be you may check this video from entagma : TD Essentials: Parallel Transport. https://vimeo.com/251091418
  19. Toms "Learning Houdini" Gallery
  20. Hey everybody, some weeks I made a simple cave builder and it worked great. But since I only used round circles, it was quite simple. Now I want to create something similar, but with a flat ground, I attached an image what I mean. Actually, I want to align the shape along the TangentU what works perfect, but at the same time on the Y-Axis so that the floor is correct. The other thing is, that it makes no sense when the tunnel has a very steep angel, that ther is a floor - so there I want it based on the angel to become from the floor shape to a round shape. Is it possible, to controll that somehow with a ramp? Thanks alot and happy easter, sant0s
  21. Nature fun
  22. Nature fun
    Homecoming
  23. Toms "Learning Houdini" Gallery
  24. Houdini 18 Wishlist
    Improve hou.Handle class so it can be used to get\set handle orientation and position
  25. Toms "Learning Houdini" Gallery
  26. Zdepth - Extract
  27. VEX Function Source Code
    Thanks, that's good to know.
