  2. HELP!! import vdb to houdini
  4. Proper Branching Topology
  5. PolyBevel problem - Modeling
  6. Advice for making paint flow down a wall
  7. Pro tips for flip meshing?
  8. stretch and squeeze by map along geometry
  9. PolyBevel problem - Modeling
  10. Hey, I'm working on a building generator and I can't find a way to align my windows properly when the base shape of the building is oval. When it's a circle everything is okay : But when the shape starts to be oval, it looks like this : Here's the vop network I built to align it with a circle shape, but not functionning with an oval shape : I don't know what I miss to get it working... Cheers,
  11. PolyBevel problem - Modeling
  12. Pro tips for flip meshing?
  13. Hello all, We are relaunching the Seattle Houdini User Group as we have hit critical mass in the Puget Sound region so we can host this events regularly. The first meetup is a smaller get together so feel free to come by if you are in the area. Thanks, - LaidlawFX
  14. Good evening everyone! One problem PolyBevel does not work. Can someone tell me? I can’t get a smooth bevel around the edge. See here that I uploaded a GIF video and also a HIP project. polybevel_voronoi.hip
  15. Vellum Constraint Attributes, what do they all do?
  16. For Each problèm in Houdini 17
  17. lookat Vex function
  18. FOR EACH LOOP metadata
    Thanks, but, I have this "Feedback each iteration" but it output all generations...
  19. Camera Projection from Moving camera
    Hi there, I have been scratching my head about how to project a texture form a moving camera that gradually reveals the footage onto a deforming. Everyting good and easy if the camera is still, but the problem arises becasue this particluar shot has a long back dolly close to the ground so i guess i would need to project all the frames of the said plate onto it. In other words, in frame number 1 you can not see some part of the plate that you can see in frame number 100. How would i need to approach this problem? Mny Thanks Frankie
  20. lookat Vex function
    Hi Antoine, the lookat() function is mainly there to make pigheads stare at spheres. But it might also work on lines ; ) vector pos_target = point(1, 'P', 0); vector pos_geo = getbbox_center(0); matrix3 rot = lookat(pos_geo, pos_target); v@P -= pos_geo; v@P *= rot; v@P += pos_geo; lookat.hipnc
  21. FOR EACH LOOP metadata
    use Feedback mode in Block End / Gather mode. That way, you only output the last generation.
  22. Advice for making paint flow down a wall
    Same I need help with this as well, somehow the liquid is just too thick and I couldn't control it no matter what attribute I adjust.
  23. Большое спасибо, работает!
  24. lookat Vex function
    https://www.sidefx.com/docs/houdini/vex/functions/lookat.html Computes a rotation matrix or angles to orient the z-axis along the vector (to-from) under the transformation. matrix3 lookat(vector from, vector to) matrix3 lookat(vector from, vector to, float roll) matrix3 lookat(vector from, vector to, vector up) Can you explain me how to use this function to have a line along the z axis, anywhere is space, point to another point in space ? I don't understand what the from and to vector are.
  25. Audio channel to controll motion from MotionFX.
    Ah thanks Ikoon. I was afraid I couldn't just pick a frequency for just the drums and voice. Thanks for detailed explanation. I noticed that MOPs actually uses the COPS nods and such. Just installed it, did a small tutorial about it. MOPS seems to give a better overview on the controls from CHOP. So this might work Probably will dive into sonicvisualiser later Thanks again Ikoon t
  26. And a comparison of "Polyreduce" SOP vs "GameDev Dissolve Flat Edges" SOP :
  27. You may try the MOPs Audio Falloff: https://vimeo.com/273252739 Or you may dive into CHOPs, and use Band EQ Chop https://www.sidefx.com/docs/houdini/nodes/chop/band.html and then, on equalized spectrum, try to use the Trigger Chop https://www.sidefx.com/docs/houdini/nodes/chop/trigger.html
