  2. In/Active Constraints
  4. Hi Guys, The scene is suppose to a transition bettween clear sky to cloudy wheater. I made an single cloud look using sphere feeding an cloud SOP then i animated the density field inside the sky SOP, after i convert the sky SOP to an polygon VDB. However when i try to use the polygon VDB to feed the cloud SOP, it wont work. (i figured out that was something when convert sky SOP to polygons, but not sure at all) my second attempt was export an sequence vdb, with no luck again. Any light on the tunnel???? anim_cloud_v00.hip
  5. Exploding Fruit!
  6. Hair inherit groups from skin
  7. Yesterday
  8. Hair inherit groups from skin
  9. RBD Collision Problem
  10. egg explosion
  11. Add color to existing color based on attribute?
  12. "Mud worms".Heightfields+SOP solver
  13. Permission Denied?
  14. Vellum export alembic
  15. egg explosion
  16. Vellum export alembic
  17. In fact, I have yet to find a operator definition type that has the 'New Output' option unlocked??
  18. Nature fun
  19. Pyro renders taking way too long
  20. Hi! I create these mountains on my shape with a noise by getting that noise by affecting the @P.y attribute. Of course the mountains are thinner when my shape goes more steep, because the points distributed through the Z axis are more dense there. To resolve this I thought I should use a different Pos for the noise, so I created a grid and put it in the second input. But when I use getattrib(P) on that input and plug it into the noise, I don't get the expected results. (It seems to do nothing much) Is it that you can't use differents Noise pos' like this? Does the topology have to match with the geometry or something? How does this work, exactly? How would one go about evenly distributing the noise position along the Z-Axis? So that you have just as thick mountains everywhere, no matter how steep? Hope you can help me. Thanks.
  21. Nature fun
  22. Vellum export alembic
  23. As the title says, when I create a new Material VOP asset the 'New Output' option in the Type Properties is greyed out. If I define export variables inside my surface shader code the 'Shader Call Export Variables' VOP will not bind them. Assigning values to eg. Cf directly in the VEX Surface code does nothing. How could I output eg. a vector from a Material VOP Asset?
  24. Last week
  25. egg explosion
  26. Nature fun
  27. Animate it by hand. there are three basic types of expression based animation between two frame values, mix and match as you like: //linear: float tx = fit($FF,1,10,2,21); //exponential: float tx = fit01(pow(fit($FF,1,10,0,1),3),2,21); //smooth: tx = fit01(lerp(1,10,$FF),2,21);
  28. Vex anoise
  29. Nature fun
