  2. Boat on waves
    Hello everyone Hello everyone! I'm new to all of the simulations of wave and boat impact... But, i have read a previous post then was pretty interesting! That just here: https://forums.odforce.net/topic/28940-flat-tank/?tab=comments#comment-164200 After i'm trying to create this example, i have problem with my simulations... My boat doesn't produce a great whitewater and wave like this example... I share you my scene, i don't know why the boat doesn't push the water like the example :/ Thank already in advance :D!! Boat_simulations_geo.hip
  3. Simple RBD hanging
    here it is. I'd want to "transfer" the position/orientation/quaternion/matrix/xform thingies of the big sphere to Null2, so that I can parent Null1 to Null2. I would get geo1, geo2, geo.... to replace the sphere. ODD_transfer.hipnc
  5. Simple RBD hanging
    Now I've got a working rope, with a proxy geo hanging at the end of it. I'd like transfer the position and orientation of the last RBD (the proxy) at the OBJECT level, but I'm stuck so far. I found info about swapping from proxy to highDef with the node TRANSFORM PIECES, but I'd like to "parent/attach" a bunch of objects instead. I'm going to make a hip file to illustrate better.
  6. Hai, Is there a way to get the data of the length from a alembic? I have to run a pipeline where I export the exact amount of frames as coming in. THNX
  7. Perfect it's working ! Thanks
  8. Hey @Lyrops, if you use "return date" insted of "str(date)", it will work. import datetime date = datetime.datetime.now() return date
  9. Simple RBD hanging
  10. Thoughts about this rig?
  11. Hi everyone ! I'm trying to display the date with a font sop using python but I'm a total noob with using python. I've found some pieces of information over odforce but I can't make it work. So far I've manage to make python work inside the font SOP but the lines I'm using sending me "none" instead of giving the date. When I'm using the same script in the Python Shell it works. I feel like I'm missing something important but I don't know what. import datetime date = datetime.datetime.now() str(date) Thanks ! Od_PythonDate.hip
  12. Contract A Rope (Vellum)
  13. Houdini Flip SIMM on a custom wave mesh
  14. Thanks Sergey, just watched the vimeo and it looks really interesting. Thanks for taking the time to upload - I'll be looking to dig through your hip at some point too. Cheers!
  15. Hiya, Thwarted at step 0 of trying to use the crowd pipeline with my custom agents: Trying to use the amazing "agent from FBX feature", but so far, the rig am wrestling with does not export cleanly out of Maya. Given a simple run cycle, I (and much smarter people than I) tried exporting a "nice" FBX to no avail. The joints export fine, animation and all, but for whatever reason the mesh is frozen to a single frame (And that's just reloading the FBX to Maya to check the export). Will keep debugging the Maya side separately (This isn't a Maya forum, last I checked ) Hoping someone here could shed light on a few points: -On the Houdini side, what is the expectation from the FBX file format? how complex is the rig-skin representation? is the skin actually bound to the skeleton, or can they exist side by side? (geo cache and animated skeleton for manipulation by Houdini) -Are there ways to export separately then re-combine in Houdini? (abc for the mesh for instance.. stick to the FBX for the joints) Any help is much appreciated!!
  16. Puddle Crown Splash
  17. Question about increasing Whitewater quality
  18. Thoughts about this rig?
  19. Houdini 18 Wishlist
  20. Simple RBD hanging
  21. Pyro renders taking way too long
  22. Houdini Flip SIMM on a custom wave mesh
  23. Realistic Dynamic Fracturing with Bullet
    hi Its nice work thank you for sharing but where is the examples scenes ?
  24. Puddle Crown Splash
  25. Preserving ParticleIDs
  26. Particle Systems on Packed Primitives
