  3. How to select a bevelled edges?
    Submitted an RFE for this
  4. Rendering Cola
  5. you may want to lower resize_container/Bounds/Field/FieldCutoff
  6. Building a beast Houdini + Redshift mainly
  7. export texture
  8. snapping point to a Null
  9. Modeling questions (remesh, polyfill)
  10. Vellum jitters non-stop without loss of energy!
  11. Yesterday
  12. This .hip needs more work to do but yes, i think it is possible too. heightfield on such shape_01.hipnc
  13. Disable Simulations on Startup
  14. Select Outside Edges Only
  15. Hello, Here is short video showing how volumes can be used to shade and texture semi-translucent organic things. Volumes For Organic Assets This approach allows to achieve close-up realistic organic look for semi-transclucent assets where SSS or colored refraction is not enough. An object with UV's is converted to signed distance volume with UVW grid. Then volume is used to set density and perform uv lookup in rendering. This way density can be adjusted by depth. I.e. not so dense near the surface and very dense at the core. Or not very dense, then dense patch like island of fat, then not dense again. UVW grid is used to texture volume. Different textures can be used at different depth. This approach allows very flexible yet powerful way to place any texture at given depth. Texture X at depth Y. I.e. big veins are 5mm under the surface. This approach is best for close up organic hero renders where SSS or refraction are not looking good enough. Attaching example file volumetric_textures_example.hip
  16. Rotate orthographic (top) view?
  17. Hi, many ways to do that... here is one: make a "group by range" node, choose points as a group type, and put 0 for start, 1 for end, and check inverse range. This will select the last point. make another group, with point 0. blast those 2 groups. a shorter way would be a wrangler: put down a point wrangler node. and type this : removepoint(0,0); if(@ptnum == (@numpt-1)) removepoint(0,@ptnum); first line remove point 0 (the first point of the line). (0,0)means : (geometry entering slot number 0 of the node , point number 0) second line reads : if the actual point number is equal to the number of points minus one (the last point of the line) third line : remove that point
  18. MSI GL63 8SE laptop
  19. Hi, When I use a Remesh on my mesh, it doesn't do anything. Tried changing any parameter. Anyone has an idea why this is? Was also wondering why I can't choose quadrilaterals in my PolyFill. modeling questions.hip Help would be appreciated.
  20. Hello. I'm trying to delete first point and last point of geometry made with line node. Somebody have a solution for this?
  21. Rotate orthographic (top) view?
  22. Neighbour count doesn't seem(?) to work?
  23. Is it also possible when you have, say, a shape like this? Can you cut out what's in the height field grid which is not the same is this shape (from top view, I guess)? heightfield on such shape.hip
  24. Neighbour count doesn't seem(?) to work?
  25. MSI GL63 8SE laptop
  26. Hi, I want to procedurally select the two end points of my shape. I read I could achieve this by counting the neighbours and using a group expression. You would think every point on my shape would have 2 neighbours, instead of only the two end points, who would have 1 neighbour. But I get very strange results. Lots have 0, a few have 3 and 2.. I don't understand it. Can someone please explain to me what is happening? neighbours doesnt work.hip Thanks!
  27. Project points on geo
  28. Project points on geo
