  2. Hi; In uv-fllaten what are pink islands? Thanks.
  3. Ring pyro burst
  5. Ring pyro burst
  6. Its missing because you dont have the 'v' attribute on the incoming geometry.
  7. Ring pyro burst
  8. Trying to set up a simple VDB collision with rotating 'fan' geometry. My issue is I am missing point velocity in my VDBFromPolygons SOP. No point.v available under Surface Attributes. What is the simplest way to resolve this? collision_VDB_missingVelocity.hiplc
  9. I wrote an article that is probably only of interest for the .1% It is a crash introduction to HDK, C++ and the mesh laplacian. https://mbaadsgaard.com/portfolio/laplacian-eigenvector-plugin-for-houdini/ Feedback is, of course, also welcome
  10. popdrag - slower particle in selected radius
  11. All the powerfull and magic of houdini, few line written to do what other software will do with addon or more hassle, and with less flexibility. If you are confused and intimidate but these vex lines, i could tell you that if you start learning houdini in a proper way from the base, this will look totally natural to you very quickly in fact
  12. I prefer to achieve this through mantra,I made some attempts,But external objects do not show the feeling of being illuminated internally.Do you have any good suggestions for this? If there is, then I will be very grateful.
  13. You seem to be everywhere, brother
  14. Yesterday
  15. Hello, I need to deform a car geometry to quickly create crash like deformation (plz, see attached). Note, I don't need a full simulation, just the final shape. What is the best approach? I tried to deform some parts of the car mesh using turbulence/anti-aliased/mountain noise, but it did not look right! Another idea is to use vellum (or bullet with soft constraints) to simulate metals and hit the car by random objects, but I am hoping for something faster. Any ideas? Thanks,
  16. Hello everyone! I'm having problem with this Solver SOP, the Prev_Frame doesn't contain the attributes I modify in the solver, like it's always the first frame. Maybe I don't understand how this work but isn't the Prev_Frame node containing the output geo from previous frame? I idea here is to check if a point velocity is above a certain threshold then start a timer on it (decreasing each frame), these points are used as a smoke emitter. The original geo is a RBD sim, at first a thought is was that but even with a test sphere it doesn't work... Please help, thanks you! panda_dust.hipnc
  17. Hello, i have an issue with the copy stamp, I created a Point wrangle where I choose randomly pieces from black or red color in a loop (its a building), so i created a variable with a random in my copy stamp and i want to paste it in a seed I created in the point wrangle, in order to copy different seed of my object on point, it doesn't work at all, it's always the same copy of the same seed... Thank for any advice, cheers
  18. popdrag - slower particle in selected radius
  19. Simulating flip from bottle
  20. Hi there, Im stuck on this problem im facing. I have created a material which basically shows the wetmap (collision history) of my flip fluid colliding with my static object. The issue I face is how to export this diffuse material as an animated image sequence in the correct uv space and unwrap of the static object model. i want to use this in maya as a shader. If anyone has any suggestions i would be thankfull forever :). Cheers.
  21. SDF from density in Dops
  22. popdrag - slower particle in selected radius
  23. SDF from density in Dops
  24. CHOPS question
  25. NASA science visualization department wants to transition from another popular 3D application to Houdini. Houdini trainer needs to be experienced in ingesting large amounts of science data and presenting it in a way the general public can comprehend. You need to be able to teach artists, that use this other application, how to transition to Houdini in this context. You will be flown to Baltimore, travel expenses paid, to provide on-site training for a week. Thanks
  26. Hello houdini masters! I have small issue, in popnet. Im trying to create moving particles on plane, but with different "speed" U can see my intention on scheme down here. Can u guys please help me? I will be very grateful for any advices. Thank u very much!! particles_issue.hip
  27. Creating bubbling lava
    https://hdbp.io/9fBpySbJ Great new-ish tutorial site with a cool interface too Also do a search here or SideFX Forum but Atom I believe posted another way to do bubbling.
