  2. hi, I am testing vellum, and have a question. When testGeo is coming up from ground, all vellum particles are influenced and pushed away. Also, when he hit ground with hummer and lift it up, particles looks being sucked into holes made by hummer. However, these particle reaction should not reach such far away distance. I'd like to know how to control the influence distance. So far, I am thinking of solutions: 1 - reduce constraint iteration, 2 - make a space between particles at emission/creation times. 3 - add more friction, increase particle separate / highres- sim, etc. This result could be ok for sand FX, but when making snow ground, this won't work. Particles should be very rigid, and particle only moves around testGeo's feet and hummer. If anyone knows how to control it properly, let me know thanks!!
  3. SOP_PointWave example questions ....
    I really respect your help ,, thank you very much.. but I don't understand what are docstrings and how to search for similar functions ?? When I click on it I find some explanation but I don't find anything about similar functions ,, only some functions have similars ... the cookInputGroups for example , I don't find the cookInputPrimitiveGroups . Is clicking on the function in the example opening the doxygen coded or what ?? This is a lot weird and funny but sorry again I am totally lost
  5. Abstract in Houdini - Course
  6. Align Geometry on Spline along TangentU and Y-Axis
  7. Houdini 18 Wishlist
  8. Stretch UI
  9. "standard" pyro and deforming mesh
  10. Hi, is there a way to set the "Invisible" toggle on a parm in Parameter Interface with python? All I could find was .hide() function which indeed hides the parameter but if the parameter is horizontally joined with a string parm, it leaves an empty space instead of having the string parm completely fill out the row. It acts the same way as the "Hide When" conditional. So I want to be able to do the same thing as when I open parameter interface and toggle "Invisible" - in python. Thanks
  11. "standard" pyro and deforming mesh
  12. I'm with Houdini 17.5 and when I import a usd/usda file, I can go through the menu , and select the usd/usda file I would like to open in the Choose Geometry dialog. My question is how can I import through a Python script, to do the same thing and not to bother the UI operations? The original post and updates are here: https://www.sidefx.com/forum/topic/65721/?page=1#post-281454 and put it here too to try to get more help. Any help is welcome!
  13. Because the three values defines an imaginary line going from 0,0,0 to the position in space described by the 3 values. That point can be far away or i can be close to 0,0,0. This way the 3 values are able to defines both a direction and a length. -b
  14. Hello, guys! Recently, I'm trying to do a project that needs to connect houdini with arduino. I want to use the data I got from ultrasonic sensor from arduino to change the height of a tube in houdini. But it seems that there are some problems of the connection, Anyone can give me some advice? This is the error message that I got from the software: Error: Unable to evaluate expression ( Traceback (most recent call last): File "<stdin>", line 2, in expression File "opdef:/Object/gwPlatform?PythonModule", line 15, in getHeight File "opdef:/Object/gwPlatform?PythonModule", line 3, in updateValues AttributeError: 'module' object has no attribute 'updateFrame' (/obj/gwPlatform1/tube1/tube1/height)) And here are some screenshots of my project.
  15. Add smaller fracture shards to an Fracture object
  16. 17 export alembic with material?
  17. Greetings! I have 5 branches that have their own unshared edge group. The group is called "widen". I put these into a for each to be able to modify the group for each individual piece with a soft transform. So first I use the $GCX, $GCY, $GCZ in my soft transform and that works, but only for the first iteration of my for each and for the other iteratons the pivot doesn't change from the first iteration. How do I get the pivot to the center of all groups in a for each?
  18. 17 export alembic with material?
  19. h17 how to export alembic with material?
  20. Does anyone know how to get Point World/Pref in a shader (not an AOV) in HtoA? I'm trying to make a worldspace height mask. Embarrassingly I can get it fine using MayaSamplerInfo3D but it feels dirty (and presumably horribly unoptimised) to do it. Thanks!
  21. If you use raytracing or pbr render engine you can increase stochaistic samples up to like 128 to remove most of the noise without increasing render time too much, otherwise you are gonna need to bring pixel samples up - the value you are using is simply too low. Also your volume does not appear grainy in the viewport because it is being rendered by OpenGL, completely different than mantra.
  22. Need help on beach waves
  23. Hello, I'm attempting my first project using smoke as a density volume through which an identical volume collides, generated from VDBfrompolygons. I can't manage to figure out why the render appears so grainy - sample JPEGs attached. The VDBfrompolygons voxel size is 0.1, & my smoke object division size is 0.1. I've made sure the rendering engine is micropolygon PBR. I'm using a couple of hlights & a sunlight, making sure they're set to "Depth map shadow" shadow type, shadow quality set to 2 & pixel samples are 2x2. My experience with lighting is extremely limited, so any feedback regarding this would be valued very much. The whole scene looks so much cleaner in the scene view than in the render view, not at all realistic as I would expect it with the application of shader materials to the objects. I must be doing something very wrong. Thanks in advance for any ideas.
  24. Yesterday
  25. Hello, I am able to select visible geometry manually, or even make a script to toggle the option to select geometry manually. But I'm wondering if there is a way to automatically select visible geometry only via a script? I have been unable to figure it out but it would be awesome if possible (may not be possible though?). Thanks! Ant
  26. You'll want a polyframe SOP then. Fiddle with the settings, it'll do what you want. If that doesn't work you'll probably need to do a double cross product with the normal and the vector towards the "center" of your building.
  27. source flip fluid with velocity
