  2. A little update on the problem I have, maybe someone knows a solution Cluster_Individual_Problem_01.hip
  4. Simulating flip from bottle
  5. I imagine my answer is not ideal but the only instance I've seen that enables lighting output from Maya and Houdini to match is using Arnold. Scene descriptions from Arnold produce exactly the same result as they use the same lights and materials. This means your Houdini scenes only use Arnold lights, Arnold materials etc and similarly your maya scenes only use Arnold lights and materials. Without Arnold you're stuck kind of guessing and trying to match by eye or making up for it in comp later. When this is done properly, lighting setups can be passed back and forth between the two packages so long as the scene scales match.
  6. How to drive smoke and blend shape
  7. [SOLVED]Expression in Geometry ROP node
  8. Exploding vellum grains
  9. [SOLVED]Expression in Geometry ROP node
  10. [SOLVED]Expression in Geometry ROP node
  11. Hi could anyone help me with this expression that I use in Geometry ROP node in OUT context? basically I just need to look for /light/ in the string and if it`s there replace it with /fx/ Here`s what my expression looks now. and If I save hiop somewhere else expression breaks `strreplace(strreplace($HIP, houdini/hip, cache), P:, V:)`/cache_001.$F4.bgeo.sc V:/project/sequences/201/201_0020/fx/work/cache/cache_001.0957.bgeo.sc $HIP - P:/project/sequences/201/201_0020/fx/work/houdini/hip $HIP(in lighting) - P:/project/sequences/201/201_0020/light/work/houdini/hip look for /light/ if there is no /light/ in the string do nothing else replace with /fx/ Thanks a lot Janis
  12. Houdini 19 Wishlist
  13. nail polish texture
  14. Houdini 19 Wishlist
  15. Solver SOP Prev_Frame problem
  16. nail polish texture
  17. Tried everything but cant make it work so it would be great if someone can edit the file i upload. Basically i would like to be able to use material fracture + cluster sop but also able to cluster individual objects together and have intra cluster and cluster to cluster groups output.
  18. Crowd Agents Bundle
  19. Polybevel issue
  20. nail polish texture
  21. i see. how about just creating those "missing" constraints yourself, merging them with the ones coming from the material fracture?
  22. I see, yes Voronoi has that option but i am using material fracture sop in the scene and it does not so i kind of need a manuel solution for this
  23. not sure if that option exists in other versions but in 17.5 it's at the bottom of the voronoi fracture
  24. Solver SOP Prev_Frame problem
  25. not looking at your file but it sounds like you want to set Connectivity Partition to None
  26. CROWDS : Walking over other agents / Constraint Network
    Hi, have you read this topic?
