Could you use the Sort by Proximity feature in the Sort node ? This "breaks" the order, but gives a starting point for each curves, which can be leveraged with some logic. Here's my take on it align_curve_starts.hipnc - Today
mehndidesign joined the community
appreciate you.
thank you so much
Nick_OA joined the community
Namended joined the community
- copytopoints
- copytopoints
Any ideas? -
