  2. nail polish texture
  4. Tried everything but cant make it work so it would be great if someone can edit the file i upload. Basically i would like to be able to use material fracture + cluster sop but also able to cluster individual objects together and have intra cluster and cluster to cluster groups output.
  5. Crowd Agents Bundle
  6. Polybevel issue
  7. nail polish texture
  8. i see. how about just creating those "missing" constraints yourself, merging them with the ones coming from the material fracture?
  9. I see, yes Voronoi has that option but i am using material fracture sop in the scene and it does not so i kind of need a manuel solution for this
  10. not sure if that option exists in other versions but in 17.5 it's at the bottom of the voronoi fracture
  11. Solver SOP Prev_Frame problem
  12. not looking at your file but it sounds like you want to set Connectivity Partition to None
  13. CROWDS : Walking over other agents / Constraint Network
    Hi, have you read this topic?
  14. Hi Everyone, I'm a student and I'm working on a project in which I need to recreate a scene similar to a Venice's canal. So I'll have buldings on both sides and water between them. There will be also a flying object that will fall and collide with water. This is the first time I work with water inside Houdini. What I need to know is what is the best workflow? I'll create a custom geometry in Maya for the container of the water, it will be an irregular shape. How do I set it as a container? Since there will be a collision, I think the best solution for water is to use FLIP fluids, right? Also if I use this way I will have many particles, so what is the best way to proceed in terms of memory, simulation and rendering? Attached you can find a really rough sketch of the idea. Thanks in advance.
  15. Hey guys, I am trying to cluster some individual objects together but cant get it working could you check? Clustering works within individual objects but does not create connection between different objects ı want the pieces look just like the seperate colored areas. thanks! ClusterTogetherProblem.hip
  16. Polybevel issue
    Hello everyone! I have an issue and can't figure it out.. I want to bevel these orange lines by using polybevel, but insted it seperates in 3 lines. Please, can you help me to understanf what went wrong? Thanks. spiral2.hip
  17. CROWDS : Walking over other agents / Constraint Network
    Any idea of how to make this dynamic constraint creation setup works ?
  18. EDIT : wrong answer :-)
  19. I have a switch with some inputs. Swtich input is linked to $F to loop through. For all of the inputs I created a detail attribute "type" e.g. "sphere" / "torus" / "box". The null node reads the detail attribute and writes the value in its parameter. I want to setup the rendering in a way that it will skip the render if the null node detects that I am rendering a "box". I thought of doing that with a pre frame script that checks the parameter of the null node if its == "box" and then skip the render. What would be the best way to skip the render here? Is there a hscript or python expression for that? Jon skipFramesByAttributeValue.hip
  20. Can't Get Rid of Particle Stepping
    it's always a good idea to set the frame rate of the timeline to something low and check what is going on in those subframes.
  21. I can't make anything follow path correctly, it simply doesnt work or when it works(with a camera) i cannot keyframe the position parameter On null nodes there is no position parameter either What am i missing? EDIT: Thanks to MiesnerMedia 1) Go inside the object you want to constraint to a path 2) create a "constraint (chop network)", go inside and add a path node. 3) select your path object in the SOP path parameter
  22. Can't Get Rid of Particle Stepping
    Have you tried to time blend the source (before the Debris Sop) ? And as said by Eric, if you cache the source, be sure to cache inter-frame as well ( see post below) https://www.sidefx.com/docs/houdini/nodes/sop/timeblend.html
  23. Yesterday
  24. Can't Get Rid of Particle Stepping
    This my be stupid but just an idea from when i read you post. is the moving source cached with enough substeps?
  25. Can't Get Rid of Particle Stepping
  26. Voronoi with thickness
    This was just uploaded a few weeks ago. Should be what you're after. https://www.youtube.com/watch?v=en0m5uDD3NQ
  27. popdrag - slower particle in selected radius
    Hi, your issue is in the pop drag node. You have "@falloff" in the activation slider, which is deactivating the whole node, because that expression isn't valid for that parameter. Think of activation as like a "global" parameter for the node. It can't be changed per particle, it's either on or off. Instead, you should leave Activation to 1 and use "VEXpressions" to multiply the drag (airresist) by your custom attribute. Also, you have "0.798" as the point number for your distance lookup in the VOP where you set the f@falloff attribute. You should be careful that it is set to the correct point number. Nodes changed are in red. particles_issue_jamesr.hip
