3delight shaders in houdini
None of this worked for me on H19.5.716 with equivalent compatible 3DL. There is no 3DL entry in Edit>Preferences>Rendering, and the only way I can access the shaders is by going to the Mat area and adding the shaders manually (right click). Then it worked. Viewport shading and everything. - Today
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
@Thoi I see what mean and asking , that was only One thing that I learn how to pull Old Stuff From users on GitHub , in Time those Files that someone Share become somehow invisible over period( or user mark those like somthing) of Time and with "Git program for windows" you can if Possible take those files ..seen some users asking on Github for Sharing those particular files @vinyvince . I need only files to Build Library
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
