  2. Contract A Rope (Vellum)
  3. Houdini Flip SIMM on a custom wave mesh
  4. Thanks Sergey, just watched the vimeo and it looks really interesting. Thanks for taking the time to upload - I'll be looking to dig through your hip at some point too. Cheers!
  5. Hiya, Thwarted at step 0 of trying to use the crowd pipeline with my custom agents: Trying to use the amazing "agent from FBX feature", but so far, the rig am wrestling with does not export cleanly out of Maya. Given a simple run cycle, I (and much smarter people than I) tried exporting a "nice" FBX to no avail. The joints export fine, animation and all, but for whatever reason the mesh is frozen to a single frame (And that's just reloading the FBX to Maya to check the export). Will keep debugging the Maya side separately (This isn't a Maya forum, last I checked ) Hoping someone here could shed light on a few points: -On the Houdini side, what is the expectation from the FBX file format? how complex is the rig-skin representation? is the skin actually bound to the skeleton, or can they exist side by side? (geo cache and animated skeleton for manipulation by Houdini) -Are there ways to export separately then re-combine in Houdini? (abc for the mesh for instance.. stick to the FBX for the joints) Any help is much appreciated!!
  6. Puddle Crown Splash
  7. Today
  8. Question about increasing Whitewater quality
  9. Thoughts about this rig?
  10. Houdini 18 Wishlist
  11. Simple RBD hanging
  12. Pyro renders taking way too long
  13. Houdini Flip SIMM on a custom wave mesh
  14. Puddle Crown Splash
  15. Preserving ParticleIDs
  16. Particle Systems on Packed Primitives
  17. Tips for Eye Candy Fluid sims
  18. Yesterday
  19. Rendering Cola
  20. Thoughts about this rig?
  21. Rendering Cola
  22. Thoughts about this rig?
  23. More Particles Following a PATH!
  24. Dynamic Particles - Houdini Rig needed
  25. Preserving ParticleIDs
  26. Particle Systems on Packed Primitives
    Trying to figure out the best approached to creating particle systems that are unique and isolated to packed primitives. Basically, I've got a rigid body shatter effect and for each packed prim I want to have an energy effect that travels along with the prim geo. I'm after a particle effect that basically 'clings' to the surface with maybe the occasional wisp or particle that escapes a tightly controlled field around the surface. I don't want a comet trail/firework sort of effect as it travels through space. Think of something like an ether fire engulfing an object: all flame and form around the source without any smoke emission. For instance, the look could be similar to stationary geo with a VDB-driven velocity field manipulated by curl noise. It feels like my base needs to be a per-piece particle system that starts as a scatter-on-surface system and...then everything I've tried just doesn't get me where I need to be. So, I guess my questions are: Is a for-each loop pretty much a given here? Any way I can avoid making the first step in the for-each loop an unpack? Because, you know, that's painful... How do I keep the particle system contained to the volume of the packed primitive/fragment geo? This isn't meant to sound as broad as it might; I've got (I think) a fairly good understanding of forces/velocity/etc in POPs/DOPs but I just can't seem to find the right combo here. The particles need to inherit the overall velocity/acceleration/transformations of the fragments as they transform, but they need to do it in a contained, volumetric fashion. My prototype tests have been getting me imagery that at one extreme looks like the particles are getting 'stamped' in space and like the comet tail at the other. I've tried a few ways to create a VDB per-fragment, and it, uh, wasn't a pretty for performance or visuals. (willing to take the perf hit for the right look, btw) I literally had not considered pyro for this until typing the ether flame description in the post. Does this sound like something suited for a pyro solver? Haven't done much pyro besides some advection hijacking. I'd be grateful for any advice. Thanks! -- mC
  27. export texture
    thank you very much
