HelenVup joined the community
mhp joined the community
Access Detail Attribute In An Expression
miying joined the community
GlennimusPrime started following Access Detail Attribute In An Expression
It's possible to add some type of noise with vops?
Hi guys, I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work! How can I fix it? Thanks for helping.
- refraction
- background
how to create this curly advected lines
djehsan89 replied to djehsan89's topic in General Houdini Questions
Thanks Hannes. -
I guess what I see are errors as well. They are annoying, but generally don't impact my workflow. Here's what I see every time I put down a Karma ROP in the /out context.
