  3. Does anyone know if it is possible in H to conform one humanoid mesh to another? I'm really looking for a procedural method for aligning dimensions and orientation of a destination mesh with a base reference source mesh. I don't think I need a morph SOP, because the destination needs to retain some (or perhaps most) of its own identity, but needs to conform the general object space that the source mesh occupies. Blender offers a sort of shrink wrap function that projects vertices from source to destination, but I'm not convinced this will do what I'm after. Any ideas on this from the community? Just a point in a general direction would be a good help. I'm quite new to H, so I know there is a steep hill ahead and I've got my hiking boots on! Thanks.
  4. How to keep the fire burning
    There are several solutions : - make a first simulation using some particles with a short lifetime (to avoid having too much of them) emitted by the comet and use them as a fuel source in another simulation using pyro. - if you already have another source but that the fuel is burnt too fast.... then lower the burn rate in the Combustion tab of the pyro sim. The combustion will last longer, but you’ll have to tweak other parameters to control the look of your flames. A nice fire is a balance between many components that affect the combustion ;-)
  5. How to keep the fire burning
    Hi, I wanted to create a scene where a object like comet collides with a building, but i don't exactly know how to give effects to the comet. Meaning i want comet to continously emit flames and smoke even though it is traveling(animated) and even afterits collision i want it to emit flames just like any real comet. Can anyone help me out in doing this?
  6. point normals
    IT WORKED THANK YOU MAN!!!!!
  7. point normals
    On the node stream of the curve, add a Point Wrangle, and on the second input of the Point Wrangle node plug the letter geometry. Put the following VEX code in the Point Wrangle: vector pos = minpos(1, @P); v@N = normalize(pos - @P); This should orient your points normals toward the geometry. You can then instance your tubes on these points (nevertheless, be careful of the orientation of the tube beforehand...)
  8. Yes Vitor, that is what I wanted, but is there a way to blur/blend the normals for those points that have more than 1 influences?
  9. point normals
    I wanted the tubes to arrange towards the geometry... how i can drive my normals towards it??? and the curve is exported from maya in fbx format....
  10. GameDev noob question - Need to create and bake texture atlases for single bricks which I am exporting to either Unreal or Unity. Is there a single best tutorial I should reference to do this using GameDev toolset? Only asking here cause I've been given a single day to demo a realtime crumbling wall. Using these textures to create my atlas https://www.vizpark.com/shop/roeben-rysum/
  11. What kind of end-result do you want to use the mesh for? Do you want the original geometry's topology? Like this? O6F9b5nQDF.webm If so you could boolean the mesh away: RnD_Infection.v01.hiplc That's the old mesh on top of the new mesh. If you get rid of the white section you still have 'nasty' topology wherever the geometry isn't defined (the inside of the column). Not sure what kind of topology you're looking for. If it's quads and perfect edge-loops I have bad news for you :D.
  12. Super crazy shit guys.. too awesome. Glad to be on the path of learning Houdini.
  13. Ok, here comes the nice and simple SOP solution: Segment the input line with a polycut node. Align the segments with a primitive node. Assign letters with another primitive node. paragraph.hipnc
  14. Frei Otto edge bundling algorithm?
  15. Here is another (similar) solution using the copy node. line_break.hipnc
  16. while easily possible without coding, I just did a quick wrangle vector startP = chv("startP"); float width = chf("width"); float spacing = chf("spacing"); float length = chf("length"); int nlines = ceil(length/width); for(int i=0; i<nlines; i++){ float linewidth = min(length - i*width, width); vector linestartP = startP + {0,-1,0}*spacing*i; int pt0 = addpoint(0, linestartP); int pt1 = addpoint(0, linestartP + {1,0,0}*linewidth); addprim(0, "polyline", pt0, pt1); } ts_paragraph_line.hip
  17. Tool to run ordered file cache nodes
  18. Yesterday
  19. Hi, I am wondering how you would do something like this. How would you get a line with one length parameter, that has a constraint after which it can go no further, and then it continues below, like a little 'paragraph', so you could create variations of that line on different 'cards'. Would really like to know how you could do something like that. Thanks
  20. VEX supports array function?
    Year 2019...had issue with this in Houdini 17.5. Solution is to add word 'function' and everything works only then. function int[] getPointsForPrim(int targetPrimID){ int pts[] = primpoints(0, targetPrimID); return pts; }
  21. Hi guys. I recently wacthed Fifty50 tutorial making a infection effect and now I'm trying to mesh the points but I couldn't achieve a better quality result. Btw I'm pretty new to houdini :{ My currently setup after points is Volume Rasterize Attributes> Vdb Smooth> ConvertVdb to polygons. Are there a better way to mesh those points? hip file attached, thank you in advance guys. RnD_Infection.v01.hip 001_Pedestal_high_poly.FBX
  22. HDA Error - Houdini 16.5
  23. HDA Error - Houdini 16.5
  24. Moderator here. @ashu_tosh_m please attempt to do this work for yourself instead of just asking for hip files repeatedly with no attempts to do it yourself.
  25. CROWDS : Walking over other agents
    Hi, Some R&D about the Crowd system. Ultimately, I want to recreate a shot from World War Z (more or less a zombie pyramid, where they are crawling over each others, but "realistically", without too much interpenetration). For the time being I am testing a much more simpler setup to allow agents walking over other agents, using regular nodes and limited code. In this scene I try to recreate the AdaptGround Behavior of Golaem crowd system (http://golaem.com/content/doc/golaem-crowd-documentation/adaptground-behavior) : my "troops" agents can walk on dead / ragdoll agents. For the time being, the dead agents are only taken into account for terrain projection, not yet terrain adaptation / foot planting. If anyone has ideas about that - foot planting and particularly floot planting on uneven ground - , I would be happy to learn or explore these directions ! :-) I have opened the agent_util.h, terrain_adaptation.h, terrain_projection.h ... VEX code used by the crowd system, but foot planting remains complex and doesn't seem to be easily hacked... (by the way, I have used some code coming from there for this setup) MORE DETAILS ABOUT THIS SETUP : - In DOP, I duplicate the ground with a poly version of it (convert heightfield to poly) : this is an object that I call "offsetTerrain" - In DOP, I duplicate the crowd geometry and keep only the dead agents : inside the crowd object (allow editing of content) I add a fetch data and duplicate Geometry into standGuyGeometry. Then with a SOP Solver, I delete all the agents except the dead ones (that happens to be ragdolls, but would work with any other agents). - I use the DOP data "offsetGeometry" of the object "offsetTerrain" in a Geometry Wrangle to create an attribute (@offsetDead) on each point of the farthest distance of intersection with the standGuyGeometry. - Using another SOPSolver, I blur the @offsetDead attribute created above, to smooth the trajectory of my future agents when stepping on the dead agents. - In the stream of the crows state of the walking agents, I add a POP Wrangle to sample the "offsetTerrain" geometry (2nd input of the POPWrangle), and get the attribute created previously (@offsetDead) - In the agenTerrainProjection1 node, I go inside and change the VEX code of the POPWrangle : I change parms.offset = chf("../offset"); with : parms.offset = f@offsetDead; Therefore, each agent has its own offset and virtually walk over the dead. testWalkOverDeads_vMocapBiped.hip
  26. Evenly Distributed Hexagons On A Object
  27. Frei Otto edge bundling algorithm?
