  3. Yesterday
  4. Oh excellent! Thanks. I'll be diving into this asap.
  5. @RT_SD I found this file with diff methods, can be useful just to Post here. vellumPressure_methods.hipnc
  6. Hey Tesan, thanks for the reply. If you scroll down a bit do the mask values stop after prim number 15? Presumably so as you have an array of 16 objects. I think I've confused myself by only doing 1 cushion. So the pressure constraint IS just a single prim so you can't actually vary the pressure values across the object on that, its all or nothing? The varying is done on the stretch and bend cloth constraints... which PE demos in his video if I paid proper attention! In my defence it is a bit counter intuitive in that to vary the inflation effect you have to do it with the cloth properties not the pressure. At least hat's how Mr Esteves has done it here. When I checked the Docs though they have that flippy inflation scene which uses a built-in @pressurescale point atttribue. Presumably that is stored on each point of the pressure prim and *does* allow you to inflate diferentially across an object using pressure, or does it??? (that flippy scene was a bit complicated as it also has a volume variable doing something as well, I will revisit it now I've cleared up my wrong thinking)
  7. @RT_SD I have this on my Spreadsheet<<<< Totally different from yours
  8. I've created a HIP that reproduces the problem in a more manageable way UPRES.hip
  9. https://ibb.co/Y2N8z8B Made a grid to use its points as your particle sources connected a pop net to it In the pop net i mainly edited the POP Source Source Tab: changed geometry source to "use first Context Geometry" to use grid points as sources Birth Tab: Crank your "Const Birth Rate" a little up and change the "Jitter Birth Time" to negative. This made the points fall a little more unperfect Attributes Tab: "Initial Velocity" gets setted to Set innitial v and than adjust the variance slightly of x and z. The points will not fall straight downward but a little left and right. i added an additonal nodes like "popinteract" to get them a bit together if they are close or add some forces to mak their movement a little more random like a small "pop wind" or so Outside the Popnet i added some additional nodes so the points get geometry. added a "attributeadjustfloat" with a operation as "set initial" and Pattern Type as "Random" with Min/Max values to my likeing (this randomly changed the size of the "droplets") added a "vdb from particles" node with quiet a small point radius and smaller voxel size. added a convert vdb and set it to polygon to get the final geometry. https://ibb.co/TPxDzsr
  10. I watched Paul Esteves' Hive froma few days ago, and followed his example for inflating a cushion using pressure constraints. I wanted to understand how to control pressure with animated antributes. I can't get his VEX code to work, and I can't understand why it doesn't, but worse I don't understand why it would if it did! (It doesn't vary the pressure across the geometry). He's setting a mask attrib on the main geo, then referencing this on input 3 of a Geometry Wrangle in the solver set to the ConstraintGeometry stream. Here's the code, with my atribute inserts for saving out the varibales so I can try to see what's happening in the spreadsheet. int pt = primpoint(0, @primnum, 0); i@mpt = pt; float falloff = point(2, "mops_falloff", pt); f@mask = falloff; falloff = fit01(falloff, chf("min"), chf("max")); f@restlength = f@restlengthorig * falloff; The code is using primpoint() to get the point number of the first vertex of each constraint prim, storing it in pt and multiplying this with the mops_falloff mask and saving it to @restlength of the pstretch group (named in the Pressure constraint SOP). But when I inspect @mpt ('mpt' so it's next to 'mask' in the spreadsheet), its all zeros. 'That would explain why it's not working' I think... iiuc though, the pressure contraint is just a single polyline, 1 prim, connecting many points stored in an array (@pts) and so has just one restlength attribute. So I don't see how this code could write the differnt masked values as there's only a single entry for it. I must be misunderstandning something but cannot figure out what. See grab. Here's the part of the vid with the code in a Geometry Wrangle in the Vellum Solver:
  11. A noob grains upres question here… I created a massive fracturing grains sim with Vellum at a low-ish resolution, and I'm using the grains' velocities to drive smaller dumber particles. When using the POP Advect by Volume, the particles are pushed around correctly as expected, but when they exist the Velocity field they slow down dramatically almost to a halt. This is because I am using "Treat as Wind" with very high "Air Resistance" values, to counteract the Gravity force. How can I sample the Density of the same volume, and use that to influence the "Air Resistance"? This way the core of the volume will stick to the Velocity, and as we get further away from the core, the Velocity will have less and less influence, with gravity taking over... I spent hours on this yesterday, trying to find a way to bring the volume Density into the DOPNet as a sort of falloff for the POP Advect by Volume node… I even tried transferring the volume density to the Grain source points in SOPs as a float value, hoping I could hook strength data out of them that way, but again, just not luck at all! I’m aware this must be incredibly simple to do, but I just cannot figure it out at all. There doesn’t seem to be any kind of masking options available in the nodes I’m using. One kind Facebook user on the Houdini Artists group told me this VEXpression could be pasted into the POP Advect by Volume node: @airresistance *= fit(length(volumevelocity), 0, value, 0, 1); value = the speed value where you want the resistance to be full. However, this is not referencing density, and so far, isn't working anyway - but I get the idea.... Can anyone advise on the best steps to do this?
  12. Here is one way to do it you can play inside the pop solver how much the particles live, etc fx_particle.hip
  13. This is what would be final goal, but this was done in C4D
  14. Last week
  15. @Librarian I want to emit particles from point on top of the sphere a these emited particles going down from edges/lines, that I've marked, I mean, I'd like to determine the path for particles. But maybe I can't describe it well enough.
  16. @CCILko if you play with this you can achieve that , or you mean Something else ...exactly on those selected curves or?? More info Please , Final Goal??
  17. Available at GUMROAD: https://ae43ae43.gumroad.com/l/bahri B-System is a SOP node editor for instances, much like a Copy To Points node with an integrated editor that lets you add, delete and move pieces directly in the viewport. Key Features: Viewport UI with handles and transform tools inspired by Blender, making editing a lot more direct and ergonomic compared to using native Houdini tools. A palette for picking instances straight in the viewport, and a workflow for defining assemblies and reusing them to build detailed compositions of instances. Automatic hierarchy when placing instances onto other instances, creating a branch-like network that allows hierarchy driven selection and editing. B-System is intended as a quality-of-life enhancer and integrates well with standard Houdini workflows. It condenses a lot of utility otherwise scattered across multiple nodes and focus them into a single interface. Reducing clicks and giving direct control over instances in a SOP context. Tutorials Viewport, handles and editing Node usage, palette and assemblies Geometry, attributes and groups Examples and use cases Docs https://github.com/aeaeaeaeaeae/bsystem
  18. I don't want to start another topic unnecessarily, but how can I do this using popnet? I'd like the particles to go down from that single point
  19. the fluid has "surface" SDF field, sample from that field to select what you want excluding the bound container
  20. Man, this is awesome, thanks a lot for the quick tutorial, I'll test it out!
  21. In karma CPU you can use one shader for snow and use grad field instead normals
  22. For volume I used simple karma pyroshader and render this pass in karma xpu. For reflections, i cant found solution for XPU yet so I use karma CPU with combination of two pbrreflect one for overal reflection and one for specle. Also I convert volume to mesh for it. For specle I use voronoi noise and samplesphere to randomize normal direction
  23. Disable openCL neighbor search in solver
  24. create another tube with same divisions and copy uvs from there easy_uv_copy.hip
  25. I am using the H123 slice tool to slice geometry and I want to export every slice as a .stl and a text file that I generate in a python node for every slice. So far I am doing the exporting manually for every slice but that gets old quick and I wonder how to automate it. The H123 slice tool is a paid tool so I can't add it in my attached file. I made a simplified setup though. The slice tool adds a primitive attribute called cutID for every primitive and I use blast to remove the rest. In the attached setup I am using the connectivity node to create a primitive attribute instead of the slice tool and then step through the slices with the frame slider. I.e. the filepath the python script exports to looks like: $HIP/$F.file However, the real slice tool uses a different naming scheme for the cutID, something like cutID=102130, 102131, 112130, .. and I'd like to iterate over those instead of just using $F. How would I do that? And one additional, probably more complicated, issue: for every cutID I'd also like to export the slice as an stl. Can I automate this somehow? In this case, whatever a right click on the blast node and "save->geometry" does. file_export.hipnc
