  2. Fully procedural, destruction ready building.
  3. Fully procedural, destruction ready building.
  5. Thanks for your quick reply Andrea! I’ll try it later today and post the result.
  6. Pro tips for flip meshing?
  7. Color Twisting
    Thats works! Thanks!!
  8. Ocean Spectrum Heigh Map
  9. Hello! First unpack your geometry before feeding it into vellum nodes, they see just one point. Second go inside the DOP network of the vellum solver. In the vellumsource change "Emission Type" from Only Once to Continuous, otherwise is going to take just the first frame. sphere_vellum_fix.hip
  10. Hello everyone! I'm trying to make a setup with spheres born in another sphere using vellum. So basically speaking, I have a Pop network shooting particles, then I feed it into a Copy to Points node and then to Vellum Configure. It works but the problem is that it takes only the first particle and ignore the others. I guess I need to update something inside vellum but can't figure out what's exactly. Can anyone take a look at the attached scene and point me out to possible solution, please? Thank you a lot in advance. sphere_vellum.hip
  11. Help[SOLVED]
    HELP Houdini 16. 0.504
  12. Genetic Algorithms in Houdini
  13. Hello everyone, Recently I tried to create a completely procedural building, which at the same time is ready to be destroyed with Houdini and this is what I ended up with. https://vimeo.com/355676432
  14. Direct Modeling HDA
  15. Sop vex ptnum vs cvex
  16. Yesterday
  17. as someone who has learned Hou in forums and looking at SideFX-s early videos , I am very thankful to your precious contribute ! i can even now hear your distinctive voice in my head now .. LOL ! thank you for your first 25 years Jeff !! .cheers
  18. Procedural OBJ splitting
  19. Sop vex ptnum vs cvex
  20. Ocean Spectrum Heigh Map
  21. To get a unique animation per instance from sops, you'll have to unpack the geometry. If you don't want to do this, you'll have to use a custom vertex shader, which is definitely not simple. Either way, the way I'd do this would be to generate some sort of stiffness attribute on the geometry, and then use that as a multiplier for some flow noise in vops.
  22. Transform packed fragments at render time
  23. OCIO Darker viewport
  24. Direct Modeling HDA
  25. it's just the viewport limit displaying your volume as lower resolution turn it off and all your approaches will display correctly
  26. Color Twisting
  27. if connect adjacent points provides good enough outline for your pointcloud then you can as well just use Triangulate 2D + Divide SOP to get exact outline, which will even match outline points nr_foot_outline_alt.hiplc
