Thanks a lot. I just checked it - however, it seems to break if I feed curves with different point counts. For instance, if I resample one of the circles it doesn't line up anymore. - Today
mehndidesign joined the community
appreciate you.
thank you so much
Nick_OA joined the community
Namended joined the community
- copytopoints
- copytopoints
Any ideas? -
