  2. Greetings! I am currently creating a digital asset in which I want to be able to create x amount of folders with the exact same options. The thing that differs is the source file path for each folder, but the same settings/options will apply. My question is; How do I keep the references of the inputs in each folder so it corresponds to the same index of the folder? If that makes sense..
  3. SDF from density in Dops
    Maybe the master himself? @Pazuzu
  4. SDF from density in Dops
  5. Best/Fast approach for car wreck look (no sim needed)?
  6. Hello! Maybe you can try with manual sculpting of the damaged parts and then add on top the noise (I think I would go with worley and antialiased). You can also get extra details with the shader and painting cracks. Doing a real simulation would be cool but between geometry preparation and setting up the simulation, you risk to lose a lot of time.
  7. Today
  8. Hi; In uv-fllaten what are pink islands? Thanks.
  9. Ring pyro burst
  10. Ring pyro burst
  11. Its missing because you dont have the 'v' attribute on the incoming geometry.
  12. Ring pyro burst
  13. Trying to set up a simple VDB collision with rotating 'fan' geometry. My issue is I am missing point velocity in my VDBFromPolygons SOP. No point.v available under Surface Attributes. What is the simplest way to resolve this? collision_VDB_missingVelocity.hiplc
  14. I wrote an article that is probably only of interest for the .1% It is a crash introduction to HDK, C++ and the mesh laplacian. https://mbaadsgaard.com/portfolio/laplacian-eigenvector-plugin-for-houdini/ Feedback is, of course, also welcome
  15. popdrag - slower particle in selected radius
  16. All the powerfull and magic of houdini, few line written to do what other software will do with addon or more hassle, and with less flexibility. If you are confused and intimidate but these vex lines, i could tell you that if you start learning houdini in a proper way from the base, this will look totally natural to you very quickly in fact
  17. I prefer to achieve this through mantra,I made some attempts,But external objects do not show the feeling of being illuminated internally.Do you have any good suggestions for this? If there is, then I will be very grateful.
  18. You seem to be everywhere, brother
  19. Yesterday
  20. Hello, I need to deform a car geometry to quickly create crash like deformation (plz, see attached). Note, I don't need a full simulation, just the final shape. What is the best approach? I tried to deform some parts of the car mesh using turbulence/anti-aliased/mountain noise, but it did not look right! Another idea is to use vellum (or bullet with soft constraints) to simulate metals and hit the car by random objects, but I am hoping for something faster. Any ideas? Thanks,
  21. Hello everyone! I'm having problem with this Solver SOP, the Prev_Frame doesn't contain the attributes I modify in the solver, like it's always the first frame. Maybe I don't understand how this work but isn't the Prev_Frame node containing the output geo from previous frame? I idea here is to check if a point velocity is above a certain threshold then start a timer on it (decreasing each frame), these points are used as a smoke emitter. The original geo is a RBD sim, at first a thought is was that but even with a test sphere it doesn't work... Please help, thanks you! panda_dust.hipnc
  22. Hello, i have an issue with the copy stamp, I created a Point wrangle where I choose randomly pieces from black or red color in a loop (its a building), so i created a variable with a random in my copy stamp and i want to paste it in a seed I created in the point wrangle, in order to copy different seed of my object on point, it doesn't work at all, it's always the same copy of the same seed... Thank for any advice, cheers
  23. popdrag - slower particle in selected radius
  24. Simulating flip from bottle
  25. Hi there, Im stuck on this problem im facing. I have created a material which basically shows the wetmap (collision history) of my flip fluid colliding with my static object. The issue I face is how to export this diffuse material as an animated image sequence in the correct uv space and unwrap of the static object model. i want to use this in maya as a shader. If anyone has any suggestions i would be thankfull forever :). Cheers.
  26. SDF from density in Dops
  27. popdrag - slower particle in selected radius
