  2. Camera Projection from Moving camera
    up!
  3. Is it possible per-pieces scaling?
    if it's packed you can use the (nasty?) node 'primitive' which I guess is a blackbox node that does a foreach on each prim
  5. or set the pscale attribute per point before you copySOP it
  6. Is it possible per-pieces scaling?
    Run into a foreach with this expression in the pivot translate "$CEX $CEY $CEZ" of a trasnform, or in a primirive sop with "do trasnformation" enabled . Then you should be able to trasnform each primitive indipendently! Best regards Frankie
  7. Hi; Please take a look at my simple test file and help me: why "GameDev Dissolve Flat Edges", caps my model? Is this a bug? Thanks. dissolve_flat_edges.hip
  8. Non-Simulated Flame (+hipfile & notes)
  9. Hello; In "Transform SOP" (or maybe other SOPs), is it possible to do a Per_Element scaling? I mean to scale each pieces based on it's bbox_center pivot, not based on main pivot (pivot defined in transform sop). In 3DSMax you have several option to scale selected pieces of a geometry which is awesome ("Use Selection center", "Use Pivot point center" , ... ). Thanks.
  10. Proper Branching Topology
  11. Matrices - CG Forge - Quicktip
  12. Hi Guys... How are you? I know there is a lot of information there that try to explain why this issue happens. However, I´ve tried to set up a basic scene to replicate the most common problem out there The scene attached is not the final or nothing at all... It was at the point of testing when I'm writing this post HOUDINI COLLISION FLIP ISSUES The main idea is this: Making the inside of the character-filled with liquid (just a little more than half). The liquid MUST be the same at all time. I had to invert signs of the static object to make it "work" And here the magic dust came along. THE LIQUID DISAPPEAR I´ve tried the following attempts with no luck so far: Reduce the grid size to 1 so the voxels of the flips have the same size of particle separation, Reduce the Particle scale to 1 to avoid conflicts in collision Try to multiply the scale by 3 to make it bigger and up the timescale of the solver to match it. I also try to advect the collision field with a volume source with VDB but it was worst and I discard that option in the minute Thoughts: I think it has to be with the particle collision mixture between volumes and particles. For some reason (i think particle accumulation) the solver reaps particles that are very close together and in the next frames, it does the same thing over and over until you are left with no particles at all... I tried to adjust the reseeding and even not reseeding at all and no luck either... It will be SO COOL to finally leave this point crystal clear to avoid future users to melt their brains out Cheers to all Peace! Wolf.rar
  13. Yesterday
  14. H17 Water Rendering Issues
  15. Proper Branching Topology
  16. Pro tips for flip meshing?
  17. Align geo with normals on an oval shape
    I finally managed to find a solution : I've separate the circle in two parts : one with the points where I copy my windows, and the other is the original geometry where I want my windows to be aligned with (to do this, just duplicate the circle and double the divisions, and then do a grouprange with an offset and keep the part you want to be the source of the copy (the points in blue are the ones from the original geo and the orange ones are those where I copy the geo)) Then, I compute normals based on the tangent u (with a polyframe sop) from the original geometry and I transfer it to the points I want to copy my windows over, and I rotate my windows by 90 and then boom, it's aligned. I've attached a hipfile because I think my explanations are really non-understandable Cheers, Align_the_windows.hipnc
  18. HELP!! import vdb to houdini
  19. Proper Branching Topology
  20. PolyBevel problem - Modeling
  21. Advice for making paint flow down a wall
  22. Pro tips for flip meshing?
  23. stretch and squeeze by map along geometry
  24. PolyBevel problem - Modeling
  25. Hey, I'm working on a building generator and I can't find a way to align my windows properly when the base shape of the building is oval. When it's a circle everything is okay : But when the shape starts to be oval, it looks like this : Here's the vop network I built to align it with a circle shape, but not functionning with an oval shape : I don't know what I miss to get it working... Cheers,
  26. PolyBevel problem - Modeling
  27. Pro tips for flip meshing?
  28. Hello all, We are relaunching the Seattle Houdini User Group as we have hit critical mass in the Puget Sound region so we can host this events regularly. The first meetup is a smaller get together so feel free to come by if you are in the area. Thanks, - LaidlawFX
