Foam/Spray Example file?
photoreel
Lets see if we can't get to the bottom of this.
In a Mac Terminal window -
$ cd /Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources/
$ source houdini_setup
The Houdini 11.0.581 environment has been initialized.
#.....................now make sure you have HOUDINI_PATH setup ok, finally run houdini .............
$ houdini
I figured it out how to launch Houdini from the command line. Unfortunately, after launching it from the command line HOT was still not working. Thanks for your help today. I don't want to monopolize your time though. I'll see what I can do to get HOT running on my own.
Thanks again,
Michael
