Sign in to follow this
Akabane
Volumetric LitFog + object with transparent material = shadows?
Hallo guys!
Basically I have a scene with some lights, a fog object and a vlitfog shader.
Then I have a plane (3d card) with a texture with alpha on it - what do I have to do to make the litfog use the alpha to project the correct shadows? Right noetting no shadow at all.
Using raytrace shadows to test, and if I use a sphere instead of the card, it works...
Tips and hints? If there isn't any nice way to do this, any ideas? I was thinking about scattering points on the card, project the alpha texture on top, cut all the points that aren't white (so alpha=1), and brutally particle meshing them...at least that way mantra would have a proper geometry to work with...
Thanks!
EDIT: I realize it might be a surreal request as I get that to be volumetric...it should have a solid object.
Just wondering if there was a way to cheat it aside from creating actual geo from the picture! (which I'm doing now)
Edited by Akabane
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
