Sign in to follow this
m0rtezaaghili
My python Code Not working
Hi guys
i'm newcomer in Houdini, my simple code not working and don't show error in Houdini console!
i changed the Tag Name to "osk" from "osm" but i don\t see error 'Bad file type' in console.
import xml.dom.minidom
document="""
<osk version="0.6" generator="CGImap 0.1.0" copyright="OpenStreetMap and contributors" attribution="http://www.openstreetmap.org/copyright" license="http://opendatacommons.org/licenses/odbl/1-0/">
<bounds minlat="40.7432000" minlon="-73.9897000" maxlat="40.8052000" maxlon="-73.9304000"/>
<node id="1420631950" lat="40.7711745" lon="-73.9792204" user="Aaron Lidman" uid="53073" visible="true" version="2" changeset="15468871" timestamp="2013-03-23T17:11:31Z"/>
<node id="1420631974" lat="40.7716867" lon="-73.9779803" user="Aaron Lidman" uid="53073" visible="true" version="2" changeset="15468871" timestamp="2013-03-23T17:11:31Z"/>
<node id="1420631985" lat="40.7694268" lon="-73.9788969" user="dchiles" uid="153669" visible="true" version="1" changeset="9189979" timestamp="2011-09-02T04:12:03Z"/>
</osk>
map = xml.dom.minidom.parseString(document)
if (map.documentElement.tagName != "osm");
print('Bad File Type')
return
[/CODE]
Thanks
Share this post
Link to post
document="""
</osk>
if (map.documentElement.tagName != "osm"):
[/CODE]
You have a ; instead of :
[size=4]also return can/should only be used in functions[/size]
Share this post
Link to post
if your real code is part of the function and indents are correct (like if() statement should be aligned with map)
then the only error is that you've put semicolon after if() instead of a colon
so it should be
return
[/CODE]
EDIT: late reply
Edited by anim
Share this post
Link to post
document="""
</osk>
[/CODE]
if your real code is part of the function and indents are correct [size=4](like if() statement should be aligned with map)[/size]
[size=4]then the only error is that you've put semicolon after if() instead of a colon[/size]
[size=4]so it should be[/size]
[CODE]
return
[/CODE]
EDIT: late reply
Thank you Both of my friends
but it not working and i don't know why my Houdini console is not showing in popup
Share this post
Link to post
open Window/Python Source Editor
paste this there (hopefully it comes through with correct indents)
def go():
document="""
</osk>
if (map.documentElement.tagName != "osk"):
return[/CODE]
press Apply
then open Python Shell and type
[CODE]hou.session.go()[/CODE]
it will execute your function defined in python source editor, it's easier to debug that way than writing everything in shell
Share this post
Link to post
Thanks Dear Tomas
its working, but i have a question, why Houdini console not running for me?
edit:
houdini console is working perfect!!
Edited by m0rtezaaghili
Share this post
Link to post
in my experience the Houdini Console don't show up if it has other output available
usually while I have Python Shell open all python outputs are shown directly in there
or while i was working on Linux they were output to Linux Shell
otherwise I didn't have a problem of console not showing up
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
