Random switcher inside for each loop
Fyre
I'm trying to make a random switch inside a for each loop to assign one of four different noises to the primitive in the current loop.
I cant access $PR from inside the for each loop as its just looking at one primitive at a time, how can I get each loop to choose a random node?
If it helps the objects are in separate primitive groups before the for each loop.
Cheers
Edited by Fyre
  • 2 years later...
Stamp really does not show a performance penalty until you are over a few thousand points. So it is still quite valid on lower point count geo. And even if you have a 60,000+ point object you can still leverage stamp() and just write out the result after the stamp operation. Place a FileCache node after your massive stamp operation to recover performance.
