ismaelvm89
One simulation 2 densities
Hello,
I'm doing an exercise of the launch of two smoke grenades .
My problem arises when once made the simulation I want to save each smoke in a different file to give different shaders . I cant do it because both smokes are in the same "smokeobject1".
Each smoke interact with each other.
Thanks!
Share this post
Link to post
Looking at it now, I was actually wrong in what I answered you on Vimeo - I confused Mantra and Arnold's volume shaders. Now, you could build a (or modify the Pyro-) shader to do what I said, split up the fields in one shader, but you can't add fields in the shader GUI, you gotta do it in SHOPs.
But it's also redundant as I at least thought you had two different volume objects in DOPs - with one object there's no way to split it up "after the fact". :(
Share this post
Link to post
Hello and thanks again Farmfield ! I discovered this and it seems like my job. Its quite different because i have 2 sources with differents parameters but I will try that.
if i create two scalar fields, it does not work. I am doing something wrong.
Edited by ismaelvm89
forgot something
Share this post
Link to post
Learning is one thing, but even more for developing stuff, taking it to the next level - or as my focus usually is, simplifying it as much as possible. :)
And coolness, I will definitely check it out.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
