Sign in to follow this
traiano
obj selection through phyton shell
viewer = toolutils.sceneViewer()
objsel = viewer.selectObjects("Select objects and press Enter",
        use_existing_selection=False,
        allow_multisel = True,
        quick_select=True,
        allowed_types = ('cam','hlight','null','geo','subnet'))
I can select my geo container node but how do i reach what I have inside the container through the phyton shell?
Share this post
Link to post
There is a method for each node called children(). That is how you inspect what is inside.
for node in objsel:
    for n in node.children():
        t = str(n.type())
        print n.name()
Edited by Atom
Share this post
Link to post
this command shows me the texture im using on my material for the geometry:
print hou.node(“./mat/clay”).parm(“basecolor_texture”).eval()
i can change to a new texture:
hou.node(“./mat/clay”).parm(“basecolor_texture”).set(“path_to_the_new_texture”)
I would like to create a dynamic texture in the shell by giving a color and write letters and numbers on it, all inside houdini so i can feed this to a neural network that has to learn. any ideas?
Edited by traiano
Share this post
Link to post
resolved through COP SHop and VOP
Edited by traiano
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
