Sign in to follow this
haveahapyday
Art Directing Falling Cloth Tips/Techniques
greetings!
i've been tasked with creating a falling handkerchief that lands on a head, completely covering the face. it's 85% of the way there, but the last 15% is eluding me. found a few good resources here on odforce and the net, but now i find myself in a "guess drop position + resim" loop. i haven't done much cloth before, so i'm not certain if that is what it comes down to in some situations. i'm looking for any techniques to direct how the cloth falls and ensure it lands on the face.
brief summary of what i've tried:
- if i position the cloth geo above the head, landing the cloth on the face is easy enough. however, then it's just a boring, flat square falling until it deforms with the face.
- to add detail while falling, i created a constraint that pinches and spins the corners together before dropping. i like the details it creates, but find the pinching turns the cloth into a shuttlecock. when the cloth contacts the head it doesn't unfurl nicely, just kind of hits and slides off.
- turned the pinch constraint off and used a vortex force to generate spin on the falling cloth. definitely a step in the right direction, good detail and motion. the issue now is i don't know how to land the cloth without guessing at an initial drop position and constantly resimming.
- made an attempt at using a pre-sim'd cloth as the embedding/rest/target geo in the cloth object node. no progress there, although i'm not sure if i'm using those settings properly.
if there are any fabric wizards out there, i'd eternally appreciate any wisdom on how to add natural motion to a falling cloth and still have it land in a specific location.
thanks!
handkerchiefFace_haveahapyday.zip
Share this post
Link to post
found a good method to solve this. i ended up making two separate sims and then used lerp() in a pointwrangle to interpret between the two.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
