Output render file naming
mapra
Hey!
I was wondering if anybody knows how to bring the camera name into the file name when rendering with redshift.
I was trying to use the following today: "$HIP/render/$HIPNAME`_``chsop("RS_renderCamera")``_`$F4.exr"
the problem is that `chsop("RS_renderCamera")` gives you not only the camera name but puts the /obj in the beginning: "/obj/cam1". So when you render, instead of naming the file "Name_01_cam1_0001" it creates a subfolder called "obj"
I was wandering if there is a possibility to strip the beginning of a string or another solution to get the camera name into the file name. Something like $CAMERANAME would be nice :)
Best, M
I tried this one, it didn't work for me, I guess its for mantra?!
https://www.sidefx.com/forum/topic/55206/
Hi Marian,
EDIT: sorry for the previous code, this one is better:
$HIP/render/${HIPNAME}_`opname(chs("RS_renderCamera"))`_$F4.exr
Those curly brackets are needed, because without them $ searches for the variable HIPNAME_ ... because _ can be included in the variable name.
Edited by ikoon
  • Thanks 1
