Sign in to follow this
StepbyStepVFX
CROWDS : Walking over other agents
Some R&D about the Crowd system.
Ultimately, I want to recreate a shot from World War Z (more or less a zombie pyramid, where they are crawling over each others, but "realistically", without too much interpenetration).
For the time being I am testing a much more simpler setup to allow agents walking over other agents, using regular nodes and limited code.
In this scene I try to recreate the AdaptGround Behavior of Golaem crowd system (http://golaem.com/content/doc/golaem-crowd-documentation/adaptground-behavior) : my "troops" agents can walk on dead / ragdoll agents.
For the time being, the dead agents are only taken into account for terrain projection, not yet terrain adaptation / foot planting.
If anyone has ideas about that - foot planting and particularly floot planting on uneven ground - , I would be happy to learn or explore these directions ! :-)
I have opened the agent_util.h, terrain_adaptation.h, terrain_projection.h ... VEX code used by the crowd system, but foot planting remains complex and doesn't seem to be easily hacked... (by the way, I have used some code coming from there for this setup)
MORE DETAILS ABOUT THIS SETUP :
- In DOP, I duplicate the ground with a poly version of it (convert heightfield to poly) : this is an object that I call "offsetTerrain"
- In DOP, I duplicate the crowd geometry and keep only the dead agents : inside the crowd object (allow editing of content) I add a fetch data and duplicate Geometry into standGuyGeometry. Then with a SOP Solver, I delete all the agents except the dead ones (that happens to be ragdolls, but would work with any other agents).
- I use the DOP data "offsetGeometry" of the object "offsetTerrain" in a Geometry Wrangle to create an attribute (@offsetDead) on each point of the farthest distance of intersection with the standGuyGeometry.
- Using another SOPSolver, I blur the @offsetDead attribute created above, to smooth the trajectory of my future agents when stepping on the dead agents.
- In the stream of the crows state of the walking agents, I add a POP Wrangle to sample the "offsetTerrain" geometry (2nd input of the POPWrangle), and get the attribute created previously (@offsetDead)
- In the agenTerrainProjection1 node, I go inside and change the VEX code of the POPWrangle : I change parms.offset = chf("../offset"); with : parms.offset = f@offsetDead; Therefore, each agent has its own offset and virtually walk over the dead.
testWalkOverDeads_vMocapBiped.hip
Edited by StepbyStepVFX
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
