[SOLVED]vector distance to surface for grooming hair
How could I measure vector distance to another surface like you see here.
Not just closest point distance, but distance following the vector.
I would like to use this as length point attribute in hairgen to control the shape of groom with geo.
Cheers
Janis
Vector_length.hip
Edited by cudarsjanis
3 hours ago, tamagochy said:
use 'intersect'  function to find point on surface along vector
Hi Andrii,
Thanks for the reply!
So I`m getting somewhere with intersect, but missing still something.. What am I doing wrong here?
As when I put addpoint it does creates the new points exactly where I need them, but when I measure distance attribute, something is still not matching.
Thanks
Janis
Vector_length3.hip
Hi there,
I would use the intersect vex function, so create a wrangle and wire the tube in second input, and you can write something like:
vector pos;
vector uvw;
int prim = intersect(1, @P, @N, pos, uvw);
f@length = distance(@P, pos);
@P = lerp(pos, @P, chf("mix"));
So the original position is first input, and intersect vex function will take that position and emit ray to your target tube, and of cause the ray direction is the normal, and it will create the hit position and hit uv. So the hit position, which is "pos" in the code is the target intersected P that based on your normal direction. So compute the distance of @P and pos is the length you want.
Also you can mix the original P and intersect P to see the blending movement.
Hope this would help.
Edited by jimeng20
13 hours ago, jimeng20 said:
Hi there,
vector pos;
vector uvw;
Thanks Jie for explanation, it works!!
8 hours ago, Aizatulin said:
normalizing @N in wrangle1 and setting length to 1 in hairgen give me better results.
Spot on Aizatulin! That is what I was missing. So everything was correct in vops, just needed to normalize the N beforehand!
Cheers
I`ll add the hip here, if anyone needs it, grooming specific shape is so much more controllable than using guideadvect.
Vector_length4.hip
  • Like 2
  • cudarsjanis changed the title to [SOLVED]vector distance to surface for grooming hair
