[Solved] Create folder structure on harddrive with callback script
sant0s81
for learning purpose I would like to create a folder structure on my harddrive by clicking a button parameter.
I found examples on how to create new folders in the parameter interface - but not how to do that on the HDD.
Actually I was thinking about adding a "string parameter" (or using "multiparm block list")  to write a name and than use that parameter, to create a folder with that name after clicking on the "button parameter".
Is that possible with the callback script or does that make absolutly no sense? :D
Thx! :)
Edit: I also just found examples with a TOP network.
Does a great job. Wonder, if I can start the "cooking" process with a Button Parameter.
Edited by sant0s81
Try something similar:
import os
f_num = hou.evalParm('/obj/geo1/null/folder_parm')
for idx in range( 1,f_num+1):
    os.makedirs( os.path.join( 'a:', os.sep, 'temp', hou.evalParm('/obj/geo1/null/folder'+str(idx))))
@gemini,
thx alot, works almost perfect for me :D
When I create the NULL and add a string parameter (Language set to Python) to get the script window, I dont get the "Run" parameter you have and its not executing.
When I use a Python Sop, your code example works and creates the folders - but its looping all the time and gives me an error, that the folder alreay exists.
Is there something in the Parameter Settings, that I have to add to get the "Run" parm?
Anyway, thx again for the example, helps alot! :)
Thank you very much again @gemini
Just to finish the topic:
I modified the code a bit to add a path an project name.
I dont know if that is the best way.
If I can optimize the code, would like to know how :)
Thx alot,
sant0s
Edited by sant0s81
Morning :)
have one more question:
I would like to use toggles to pass over the names to os.makedirs .
But whatever I do, I never get the marked toggles and always only the first.
I understand, that the "Multiparm Blocklist" has an ID - but when I change the Folder Type to simple, I have no idea how to pass over the toggles since there is no more ID.
And something else I wonder how to do that: how could I create a list of folder presets and pass them over?
Thanks alot! :)
edit: In this line here I dont know, how to choose all parameters instead of "folder"
hou.evalParm('../null/folder'+str(idx))))
Of course "folder" is wrong - but I tried stuff like "*" to choose all. But of course, not working :D
Edited by sant0s81
I did some research and I think I have to give a callback script to each toggle parameter, to send the parameters name.
Is that the right direction?
Something like transfering each toggle parameter into a function that reacts on the callback script.
Dont even find words what I wanna do, sry :D
I am just trying parameters from the Redshift_ROP.
They also use the Multiparm Block (list) to choose the different AOVs.
In the Redshift_ROP, as soon as I choose an AOV like Diffuse, the string textblock changes the name to Diffuse, too.
I copied these parameters to see what they did.
But as soon as I copy the parameters to my new geometry, the text stays on the default value and is not changing automaticly.
Is there something missing?
I add the hip below.
create_folders_v001c.hiplc
Edited by sant0s81
