amin.khormaei
action for the values outside the find attribute value array
as you can see the code below:
i[]@values = findattribval(0,"point","random_number",3);
for(int i = 0 ; i < len(@values) ; i++)
    if(@ptnum == @values[i])
        @pscale = ch('specific_pscale');
    else
        if(@ptnum != @values[i])
        @pscale = ch('rest');
the second if inside the else doesn't work properly.
Specific_pscale.hip
Share this post
Link to post
Not by Houdini right now, but I think you may want something like this
int values[] = findattribval(0,"point","random_number",3);
@pscale = find(values, @ptnum) >= 0 ? chf('specific_pscale') : chf('rest');
Share this post
Link to post
thank you but your code doesn't work, I want to scale the point with random_number attribute that equal with 3 by specific_pscale slider and the rest of the points with the rest slider.
I'm tested the find, find returns the index of certain value in the array
Edited by amin.khormaei
Share this post
Link to post
I'll check once I have access to Houdini
Share this post
Link to post
seems to work exactly that way, what exactly is not working for you? attached file with the same code
Specific_pscale_fix.hip
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
