UV Layout - Pack Geo islands - orientation problem
i am trying to layout some pieces of geometry on surface. Those pieces are made of other pieces so i create an island attribute for the uv layout node to use and pack them as a whole and not each object individually. The problem is that although i have selected no rotations as you can see the uvlayout node rotates them anyway.
Anyone else having the same problem?
Is there some obvious mistake that i am missing?
