[SOLVED] Tree Sim Deform
sipi
23 minutes ago, Atom said:
Play with the Capture settings on the pointdeform. Try a a radius of 1.0.
Not really working, it becomes wobbly. See this attachment. Also it wouldn't work with more dense branches.
radius_1.mov
Actually I discovered in the help that they don't recommend to use point deform for wire stuff.
Edited by sipi
I tried adding leaves, but the branch connectors dance around. I'm not sure if this set up will work with more branches. When I enabled the secondary branches, the bonecapturebiharmonic goes off into la-la land. You may want to come up with some overall mass concept for the tree and divide the branches into various weights. With more secondary branches, they weigh down the parent branch quickly.
ap_tree_deform(1).hiplc
Edited by Atom
14 minutes ago, tamagochy said:
To use curves for deform you need to create geometry using sweep from curves and then plug to point deform.
Oh indeed, it's a more simple and faster solution! Thank you!
Ok, here is an attempt at tomogachy's suggestion. Sweep before the DOPNet, then point deform after. The scale along length doesn't really work right, because it needs to know the pscale of the point where the connection occurs, then use that value as the start of the taper. Also, some points just don't mesh well and seem stuck to neighbors?
ap_tree_sweep.hiplc
Edited by Atom
I think tamagochy's suggestion was to put the Sweep after the Dopnet and use that geometry to deform the original tree geo using a Point Deform, and I think it would work well if the Sweep SOP would generate proper geo. I just can't figure it out what is the deal with the orient attribute...
The "stuck to neighbors" issue can be solved with deforming the tree separatly by branch_level, or using a for-each with named primitive like this:
Edited by sipi
Sweep used normals along spline and up vector to orient shapes, by default after dopnet you have orient attribute you need to delete. Use foreach per branch to create shapes and then use it in point deform.
In my vol3 tutorial you will find explanation of all aspects of the meshing.
  • 3 weeks later...
Oh I just fixed the previous problem, but it's still far from a "good-looking" stuff. I want to figure out a stable setup, then start to tweak the sim.
Feel free to check out. It seems to me that deformation, and constraints are working now...
tree_4.hiplc
Edited by sipi
Now the wire sim is realtime, deforming is slower (around 3 fps), but it's getting stable. Still a lot to do...
Also, I don't know if I'm overcomplicating it or not...? I'm just happy to find any usable solution.
tree_5.hiplc
Edited by sipi
Well, not long after I post it, I realized that the previous method in tree_5.hiplc is malfunctioning. I improved and simplified it and now it's almost okey!
But I have difficulties with constraining the branches to each other. Right now I actually snap the root points of every branches to the closest point on the closest branch, and fuse them instead of constraining but sometimes the snapping flaws. Constrains would be better I guess, but I couldn't figure out how to do it.
Way A is unreliable.
Way B is almost good but with a high number of branches, it becomes unstable.
Anybody could take a look and tell me what would be the bulletproof way?
tree_9.hiplc
Nevermind, I fixed the previous unconnected pieces issue.
At last the skeleton preparing and deforming setup is working fine with as many branches as you want. I still use the fuse method, finally i managed to figure it out the way (unfortunately I couldn't make it with constrains :unsure:).
Now it's time for the leaves! :)
Any idea about the leaves? What's the best way to use the Labs Leaf Generator with a deforming tree?
tree_10.hiplc
  • sipi changed the title to [SOLVED] Tree Sim Deform
