Hi there!
I have this melting setup with a POP solver, basically scattering some points onto the original mesh and then melting then and meshing back everything again using "particlefluidsurface".
So I have been trying to get rid of this flickering on the mesh, I have over 500k points and I also tried increasing the samples and playing with the particle separation in the "particlefluidsurface" I also tried using "vdbfromparticles" but its more or less the same result.
I want to know if there is anything I can do to help reduce the flickering?
Any help on this is much appreciated
Thanks in advance
untitled10.mp4
Share this post
Link to post
Hi there,
I also tried converting those particles into a volume and the mesh back but the results were not that great
So the best so far I have is "vdbfromparticles" and then applying some smoothing and also increased the particle radius (basically playing a bit with the settings), this is giving me a much more cleaner result.
Thanks
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
