catchyid
scatter points on surface using particle separation?
I want to scatter points on a surface with a specific point separation? If use "pointsfromvolume" node it fills the entire volume of the surface, and "scatter" node does not have this "point separation" property. Is there a way to do that? Note: I need to have "point separation" property because I want to use "Pyro Source" which requires this number (plz see attached)
Tx
pointsVolumeOnSurface.hip
Share this post
Link to post
You can plug the pyro source directly to the torus, and switch the "Mode" to "Volume Scatter"
If you want to scatter over a surface, switch the "Mode" to "Surface Scatter"
Edited by ThisIsDolan
Share this post
Link to post
hmmm...wondering how come I did not see that ;) Maybe I was super tired that day ! Thaaaaaaaaaank you :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
