Recursive subdivision effect
Eyteneyer
images?q=tbn:ANd9GcSRQ5FmtUy1rlV6yqByEDt
Hello dear Houdini Legion.
I am trying to create this effect from the picture above. Try to copy on the extracted points geo, but it doesn't work properly. Please help me. I followed Matt Taylor tutorial on recursive subdivision.
My goal is to use images from COPS to copy into every polygon center, and it should scale with polygon in time.
Thanks for any advice.
recursive_sub_v01.hip
//detail
float size_mult        = chf("size_mult");
float min_size         = chf("min_size");
float max_size         = chf("max_size");
float normal_offset    = chf("normal_offset");
int use_nonuniform     = chi("use_nonuniform");
float thickness_scale  = chf("thickness_scale");
int colorize           = chi("colorize");
int random_color       = chi("random_color");
int keep_only_polygons = chi("keep_only_polygons");
// SAFE DEFAULTS
size_mult       = max(size_mult, 0.00001);
min_size        = max(min_size, 0.0);
max_size        = max(max_size, min_size + 0.00001);
thickness_scale = max(thickness_scale, 0.00001);
// STORAGE ARRAYS
vector centers[];
vector normals[];
vector ups[];
vector scales[];
vector colors[];
float pscales[];
int srcprims[];
float areas[];
// READ ALL PRIMITIVES FIRST
int npr = nprimitives(0);
for (int pr = 0; pr < npr; pr++)
    string typename = primintrinsic(0, "typename", pr);
    if (keep_only_polygons == 1)
        if (typename != "Poly" && typename != "Polygon" && typename != "Mesh")
            continue;
    int nv = primvertexcount(0, pr);
    if (nv < 3)
        continue;
    // Polygon center
    vector C = set(0.0, 0.0, 0.0);
    for (int i = 0; i < nv; i++)
        int vtx = vertexindex(0, pr, i);
        int pt = vertexpoint(0, vtx);
        vector P = point(0, "P", pt);
        C += P;
    C /= float(nv);
    // Polygon normal using Newell method
    // More stable than relying only on prim_normal.
    vector N = set(0.0, 0.0, 0.0);
        int vtx0 = vertexindex(0, pr, i);
        int vtx1 = vertexindex(0, pr, (i + 1) % nv);
        int pt0 = vertexpoint(0, vtx0);
        int pt1 = vertexpoint(0, vtx1);
        vector P0 = point(0, "P", pt0);
        vector P1 = point(0, "P", pt1);
        N.x += (P0.y - P1.y) * (P0.z + P1.z);
        N.y += (P0.z - P1.z) * (P0.x + P1.x);
        N.z += (P0.x - P1.x) * (P0.y + P1.y);
    if (length(N) < 0.000001)
        N = prim_normal(0, pr, 0.5, 0.5);
        N = set(0.0, 1.0, 0.0);
    N = normalize(N);
    // Find longest polygon edge as local X axis
    // This gives stable orientation for Copy to Points.
    vector X = set(1.0, 0.0, 0.0);
    float longest = -1.0;
        vector E = P1 - P0;
        float L = length(E);
        if (L > longest)
            longest = L;
            X = E;
    if (length(X) < 0.000001)
    // Remove any normal component from X.
    X = normalize(X - N * dot(X, N));
        vector tmp = set(1.0, 0.0, 0.0);
        if (abs(dot(tmp, N)) > 0.95)
            tmp = set(0.0, 0.0, 1.0);
        X = normalize(cross(tmp, N));
    vector Y = normalize(cross(N, X));
    if (length(Y) < 0.000001)
        Y = set(0.0, 1.0, 0.0);
    // Polygon area / perimeter scale
    float area = primintrinsic(0, "measuredarea", pr);
    if (area <= 0.000001)
        // Fallback area approximation from triangulation to center.
        area = 0.0;
            area += length(cross(P0 - C, P1 - C)) * 0.5;
    float uniform_size = sqrt(max(area, 0.0)) * size_mult;
    uniform_size = clamp(uniform_size, min_size, max_size);
    // Non-uniform scale from local polygon bounds
    // X/Y are measured in polygon local plane.
    float minx =  1e18;
    float maxx = -1e18;
    float miny =  1e18;
    float maxy = -1e18;
        vector D = P - C;
        float lx = dot(D, X);
        float ly = dot(D, Y);
        minx = min(minx, lx);
        maxx = max(maxx, lx);
        miny = min(miny, ly);
        maxy = max(maxy, ly);
    float sx = max(maxx - minx, min_size) * size_mult;
    float sy = max(maxy - miny, min_size) * size_mult;
    float sz = uniform_size * thickness_scale;
    sx = clamp(sx, min_size, max_size);
    sy = clamp(sy, min_size, max_size);
    sz = clamp(sz, min_size, max_size);
    vector S = set(uniform_size, uniform_size, uniform_size);
    if (use_nonuniform == 1)
        S = set(sx, sy, sz);
    // Color
    vector Cd = set(1.0, 1.0, 1.0);
    if (random_color == 1)
        float r = rand(float(pr) * 13.17 + 0.11);
        float g = rand(float(pr) * 41.73 + 0.37);
        float b = rand(float(pr) * 91.27 + 0.71);
        Cd = set(r, g, b);
    else
        float a_norm = fit(uniform_size, min_size, max_size, 0.0, 1.0);
        Cd = lerp(set(0.08, 0.25, 1.0), set(1.0, 0.55, 0.05), a_norm);
    // Store arrays
    append(centers, C + N * normal_offset);
    append(normals, N);
    append(ups, Y);
    append(scales, S);
    append(pscales, uniform_size);
    append(srcprims, pr);
    append(areas, area);
    append(colors, Cd);
// CLEAR INPUT GEOMETRY
for (int pr = nprimitives(0) - 1; pr >= 0; pr--)
    removeprim(0, pr, 0);
for (int pt = npoints(0) - 1; pt >= 0; pt--)
    removepoint(0, pt);
// CREATE OUTPUT TEMPLATE POINTS
for (int i = 0; i < len(centers); i++)
    int p = addpoint(0, centers[i]);
    vector N = normals[i];
    vector UP = ups[i];
    // Rebuild clean orientation.
    vector X = normalize(cross(UP, N));
    UP = normalize(cross(N, X));
    matrix3 m = set(X, UP, N);
    vector4 q = quaternion(m);
    setpointattrib(0, "N", p, N, "set");
    setpointattrib(0, "up", p, UP, "set");
    setpointattrib(0, "orient", p, q, "set");
    setpointattrib(0, "pscale", p, pscales[i], "set");
    setpointattrib(0, "scale", p, scales[i], "set");
    setpointattrib(0, "srcprim", p, srcprims[i], "set");
    setpointattrib(0, "area", p, areas[i], "set");
    setpointattrib(0, "id", p, srcprims[i], "set");
    if (colorize == 1)
        setpointattrib(0, "Cd", p, colors[i], "set");
    setpointgroup(0, "copy_centers", p, 1, "set");
  • Like 2
you're almost there:
the way you tried to get the scale from the point is incorrect
Do this instead, everything you need to change is visible in the wrangle
This works because the extracted centers have the same element number as the primitives they're representing.
And the bounding box can be used directly to scale a unit box to the size of that primitive. You can also remove measure SOP.
Posted (edited)
OMG thank you so much! Wow! Antonio, could you please help me with growing effect? Is there any way to grow this from, one big, lets say rerctangle and in 145 or more frames one by one divide gently this rectangles as i mention in reference picture))
Edited by Eyteneyer
Posted (edited)
You should start by fixing the original code so that the prims are all oriented the same way, and so that down the line, X always means world X, and Y always means  world Y. This is left as exercise. This makes it simpler to debug or control if everything is nice and aligned to start with, all oriented the same.
Other than that, it should be doable by linking the iteration count to the currents values of X and  Y , with two separate ramps functions, with something like this (not tested):
   float iter = detail(1,"iteration",0)/ float(detail(1,"numiterations",0));
and use that iter value to read from a chramp
With low iter values, you should return values close to something between 0 and 0.5
and the higher it gets, the closer to 0 or 1 it should go; this way, only one prim will dominate (visually) in the subdivision
Getting it right is the tricky part though
Edited by AntoineSfx
