rahulmsr Posted July 1 Share Posted July 1 (edited) Hey everyone, I want to share Blueprint, a shareable, node-based pipeline platform I've been developing. It is currently running in active production on a 3D animated feature film. What's different? Most commercial pipeline tools force you into a rigid asset structure, while fully custom pipelines require massive amounts of boilerplate code to handle basic things like file analysis, path remapping, and DCC environment management. Blueprint abstracts the boilerplate into a visual node graph without boxing you into a specific workflow. It’s designed to be a flexible foundation that wraps around your studio's existing infrastructure rather than replacing it. Core Architecture & Capabilities Instead of writing isolated scripts for every pipeline step, Blueprint allows you to build and visualize workflows using modular nodes: DCC Agnostic Core: Built to seamlessly interface with standard tools (Maya, Houdini, Blender, Unreal, Nuke) or DCC of your choice. Production-Proven Scale: It isn't a prototype. It is currently being used in a full-length animated feature production. Open & Extensible: The goal isn't to hide code behind a GUI. TDs can easily build custom nodes, plugins, expose specific parameters to artists, and hook the graph directly into custom tools. Shareable: Pipeline Blueprints can be shared with vendors and satellite studios to ensure everyone follows the same production workflow. This dramatically reduces the weeks of pipeline setup, synchronization, and IT/TD overhead typically required to onboard external teams. Why I'm Sharing This Pipeline TDs and Software Engineers are historically burned by "magic bullet" software. I'm putting Blueprint out there because it is battle-tested enough to be torn down by peers. I would love to get your brutal, honest feedback on the architecture, the visual UX, and whether this solves the integration headaches you face daily. DEMO ON VIMEO ON YOUTUBE: Edited July 1 by rahulmsr Quote Link to comment Share on other sites More sharing options...
