tako32 Posted July 29 Share Posted July 29 I watched Junichiro Horikawa’s lecture and created particle morph. And while searching to find a way to move the object’s pieces in sync with the particle’s movement, I came across the following article. However, the attached file has expired and cannot be downloaded, so I cannot implement the content written in the comments. Even if I don’t have to follow the particle’s movement exactly, could you tell me how to perform Voronoi morphing from A to object B? Thank you for reading it. Morph.hiplc Quote Link to comment Share on other sites More sharing options...
