road_to_cga Posted August 4 Share Posted August 4 Hello i'm starting to learn houdini and im trying to create a newspaper generator. At this moment i can't continue cuz i've set up two simulations one after another and the second one doesn't work. The first simulation is building the pile of newspapers and deforming them and the second should wrap a cord around but doesnt work The first simulation is basically this: https://ibb.co/PZSptBt4 and the DOPnet https://ibb.co/4ZLC143v And the second simulation setup is...https://ibb.co/TMqyhFcW and the DOPnet https://ibb.co/rPx6J7z I would greatly appreciate your help. Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 4 Share Posted August 4 Share what you got. Tough to say/help without looking at the .hip. Quote Link to comment Share on other sites More sharing options...
road_to_cga Posted August 4 Author Share Posted August 4 19 minutes ago, Sepu said: Share what you got. Tough to say/help without looking at the .hip. ofc, thx in advance! untitled.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 4 Share Posted August 4 can you upload the .fbx is missing Quote Link to comment Share on other sites More sharing options...
road_to_cga Posted August 4 Author Share Posted August 4 knot.fbxhere! Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 4 Share Posted August 4 So for once you scale is pretty big, I would normalize the scale of the asset first, second you are using geometry for the hair constraint, that wont work. If you are going to use hair constraints do not sweep them. If you want to keep the geo you should be using cloth instead. Quote Link to comment Share on other sites More sharing options...
road_to_cga Posted August 5 Author Share Posted August 5 (edited) 13 hours ago, Sepu said: So for once you scale is pretty big, I would normalize the scale of the asset first, second you are using geometry for the hair constraint, that wont work. If you are going to use hair constraints do not sweep them. If you want to keep the geo you should be using cloth instead. I tried another approach, now it has only one simulation. The thing is i don't know how drive the compression of the newspaper with the wrapping cord. What do you think? untitled2.hip knot.fbx Edited August 5 by road_to_cga Quote Link to comment Share on other sites More sharing options...
