Importing a .bgeo sequence and rotating each imported frame around a modified pivot
I have a quick question,
Is it possible when importing a .bgeo sequence to have the the following frames be imported on a rotational offset around a center point of a circle to the previous frame?
Also is it possible after importing the previous frame, to keeping both frames active so it shows all frames in the sequence at once ?
I'm trying to make a zoetrope and an expression of some sort would be rather helpful.
Something like this
Cheers,
Toadart
