Simchron
Dynamic Vex Variable Names?
Hi there!
Is it possible to dynamically declare variables in a for loop with the index in the variable name?
Current problem:
I want to store primitives with similar normal angles into an array. The maximum number of arrays would be 4 (cardinal directions) but in most cases the normals head in only one direction.
Thanks in advance.
Cheers
Share this post
Link to post
its possible with H14 and up ;)
using the http://www.sidefx.com/docs/houdini16.0/vex/functions/setprimattrib function
along with http://www.sidefx.com/docs/houdini16.0/vex/functions/sprintf
for example
float angleVal;
string attribName;
for(int i = 0; i < 4; i++)
	attribName = sprintf("angleDir_%d", i);
    angleVal = i; //do your math here
    setprimattrib(0, attribName, @primnum, angleVal);
in H13 and lower, the attributes have to exist before the setprimattrib or setpointattrib etc are used, with H14 and up, it will generate it for you :)
or you can store them directly as an array attribute, but in some cases it may complain if the sizes of the array are not the same (at least in Python I think)
in vex that would look something like this:
float angleVals[], angleVal;
string attribName;
    append(angleVals, angleVal);
f[]@outAngles = angleVals;
Edited by acey195
  • Thanks 1
Share this post
Link to post
Hi Twan,
thank you very much for taking the time and the detailed explanation.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
