Dops Faq
brianwal
There is a Dynamics FAQ you can download off the Houdini Exchange at: http://www.sidefx.com/index.php?option=com...er&Itemid=8
The Dynamics FAQ include:
1. How do I set up a basic ball bouncing on the ground?
2. How do I get objects to bounce around inside a containing box (or shape)?
3. How do I get an object to shatter?
4. How do I knock over (shatter) one object with another?
5. How do I control where an RBD object comes to rest?
6. How do I write out the animation channels for an RBD object, to transfer them to Maya?
7. How do I create an explosion?
8. How do I do destruction in layers, starting with the largest pieces and adding smaller ones to approved previous layers?
9. How do I create a chain of constraints (for example, a set of train cars)?
10. How do I combine cloth with RBD?
11. How do I combine particles with RBD?
12. How do I set up cloth constraints?
13. How do I tear a piece of cloth?
14. How do I blend between constraints?
15. How do I change the length of a simulation that is already approved?
16. How do I pre-roll, or offset, an animation?
17. How do I render my simulation?
18. How do I get a particle network to birth objects in a DOP Network?
  • 1 month later...
