Vinz9 Posted October 16, 2009 Share Posted October 16, 2009 (edited) Hi, I'm running Houdini 10.0.401 on a mac under windows64. I'm just starting with python in Houdini but sadly some simple procs like def dupobj(objet,nr): objn = hou.node('/obj') for i in range(nr): curCopy = hou.copyNodesTo([myNode],objn) n = curCopy[0] dest = 'sticky'+str(n.digitsInName()) n.setFirstInput(objn.node(dest)) def conobj(nr): objn = hou.node('/obj') for i in range(nr+1): src = 'path'+str(i) dest = 'sticky'+str(i) objn.node(src).setFirstInput(objn.node(dest)) stored in hou.session and executed from the shell freezes houdini most of the time. If I manage to have it work once, once my scene is launched it always works, but most of the time, if I launch Houdini, and then load my scene and execute one of the procedures, houdini freezes directly with no error. Thanks a lot for any help Vincent Edited October 16, 2009 by Vinz9 Quote Link to comment Share on other sites More sharing options...
negow Posted November 5, 2009 Share Posted November 5, 2009 (edited) Yep, same here. Amongst the first line in the Hom intro tutorial in the docs (hou.node('/obj').createNode('geo') ), freezes up every time. But only on My workstation. Another one works fine :/ Both x64, build 401 and 374. edit1: Wops, and I solved it. Just installed the corresponding python release manually. http://www.python.org/ftp/python/2.5.2/python-2.5.2.amd64.msi edit2: Nope, its back again Edited November 6, 2009 by negow Quote Link to comment Share on other sites More sharing options...
Ahmed Tausif Aijazi Posted November 11, 2009 Share Posted November 11, 2009 I am also having the same problem, using windows 7. It worked just one time but freezes all the time on just executing a simple command. root = hou.node("/obj") root.createNode("geo") If any one finds the solution please post it. Quote Link to comment Share on other sites More sharing options...
Ahmed Tausif Aijazi Posted November 13, 2009 Share Posted November 13, 2009 HI, I manage to solve it by reinstalling Houdini. As I am using the apprentice version, so during the installation i did not select licence server to get install instead i selected Apprentice licence. After the installation it worked fine. I think the problem was accessing the licence server (maybe), Any way now it works. Quote Link to comment Share on other sites More sharing options...
