Aks Posted October 24, 2009 Share Posted October 24, 2009 Hi, can any one help me with this fluid file. from past two days file was working fine, while changing some simulation attributes (not sure which one), fluid disappeared! now can't see or render fluid. thanks in advance! -Akhlaque splash.hipnc Quote Link to comment Share on other sites More sharing options...
rbowden Posted October 24, 2009 Share Posted October 24, 2009 Hello, I looked at the file and it seems to be showing up in the viewport and rendering for me... When I opened the file, I noticed that you are starting on frame 171. Try setting the start frame for the AutoDopNetwork to 171 if you are not going to start at frame 1. You may have to do the same thing for the particle fluid object inside the AutoDopNetwork also (except on the particle fluid object it is called creation frame). If you don't want to do that, you are going to have to wait for the network to cook everytime. Hope this helps, -Ryan Quote Link to comment Share on other sites More sharing options...
Aks Posted October 25, 2009 Author Share Posted October 25, 2009 Hello, I looked at the file and it seems to be showing up in the viewport and rendering for me... When I opened the file, I noticed that you are starting on frame 171. Try setting the start frame for the AutoDopNetwork to 171 if you are not going to start at frame 1. You may have to do the same thing for the particle fluid object inside the AutoDopNetwork also (except on the particle fluid object it is called creation frame). If you don't want to do that, you are going to have to wait for the network to cook everytime. Hope this helps, -Ryan Hey thanks Ryan, i tried simulating with this options. if its running perfect on your machine, i guess i need to check with other machine. -Akhlaque Quote Link to comment Share on other sites More sharing options...
