Why this happens to my Renders.
I have this network for displacing my surface. I attached a jpg sequence witch shows you how after 10 frames or so, the object starts to flickering. ( notice to last 2 frames )
Edit: I just found that this is because of the divide node, because it's number of faces is not constant during the animation.
Now the question is how can I make a node like divide to keep it's number of faces constant?
Edit2: Well, Forget it. I solved my problem using a delete node. Thanks :)
od_dis_test.tar.gz
Edited by Farsheed Ashouri
