RasmusM Posted November 3, 2009 Share Posted November 3, 2009 Dear all, I have a problem - I have been working with some patterns using the Triangulate 2D sop. It works fine on a plane ofcourse, but is there any way to apply it onto a box or any other 3d geometry? Hope someone are able to help! Best, Rasmus Quote Link to comment Share on other sites More sharing options...
jacob clark Posted November 3, 2009 Share Posted November 3, 2009 Dear all, I have a problem - I have been working with some patterns using the Triangulate 2D sop. It works fine on a plane ofcourse, but is there any way to apply it onto a box or any other 3d geometry? Hi Rasmus, This maybe a bit broad for your needs, but have a look at the Voronoi Shatter thread in the DOPs section. This contains a tool you can use to cut your geometry into Voronoi Pieces. If this seems like crazy talk... Put a Divide SOP beneath your Triangulated Plane, and toggle on 'Compute Dual'. BAM, Voronoi Pattern is the dual of the Triangulate SOP. Other than that you might be a bit limited... Good luck! cheers, -j Quote Link to comment Share on other sites More sharing options...
